Avi plays with wrong aspect ratio 4:3. GPspot states the same 4:3 (512x384) but correct seems to be 16:9 or 16:10.
How to fix avi aspect ratio?
I guess it's just a number in the beginning of file - is there any lossless corrector just to fix this single number without rendering whole video?
Thanks!
Results 1 to 10 of 10
mpeg4modifier. But not all players will use the aspect ratio flag.
I already checked mpeg4 modifier but it fails because I have Net framework 4.0.
Looks like mpeg4 modifier is outdated and doesn't work on contemporary system:
"Net Framework Initialization Error" Unable to find runtime to run this application.
I have several other Net Framework applications, which work flawlessly .. like Cd Burner XP
Installing old net framework versions over new one doesn't feel secure in the sense of system stability.
You can have several frameworks installed without any problems. If something requires framework 2.0 then wont it work with just framework 4.0.
Yes, like Baldrick said, they DON'T interact with each other, at least AFA large version numbers. So you can have v1.1, v.2.05, v3.5, and v4.0 all on the same machine with no corruption.
However, as regards your original problem...
If it's encoded in an AVI container, your options are very limited. Since AVI doesn't really support ARs on the container level, it's up to the actual video codecs to support it: DV, Xvid/Divx, MPG does. Many others don't. Like was said before, this needs to also be supported on the decoder in the player (settop, etc). And most of those apps that DO support it set that in stone during the encode, so you can't (often) successfully change it after the fact.
Scott -
Thanks, but which of these oldies is correct to add to 4.0? 2.0, 3.0, 3.5? MS states that there is newer version already and doesn't suggest 2.0 any more.
3.5 states that it's an update to version 2 and 3. Any ideas? -
You could try repairing .NET Framework.
See "Method 2: Repair the .NET Framework" here:
http://support.microsoft.com/kb/923100
When this has done, you can then install version 4 from here:
http://www.microsoft.com/downloads/en/details.aspx?FamilyID=0A391ABD-25C1-4FC0-919F-B21F31AB88B7 -
I downloaded and installed .net framework 3.5 and after that
mpeg4modifier did a great job fixing aspect ratio!
Thanks to everybody!
Using VirtualDub to Fix Aspect Ratio
By Djard in forum EditingReplies: 15Last Post: 10th Sep 2013, 18:33 -
How to fix MPEG encoded with wrong aspect ratio?
By Talayero in forum Video ConversionReplies: 2Last Post: 21st Oct 2008, 10:29 -
Video aspect ratio conversion
By cd090580 in forum Video ConversionReplies: 15Last Post: 22nd Sep 2008, 07:08 -
Wrong Aspect Ratio on Toshiba 1850 Portable - How To Fix?
By bluehz in forum Video ConversionReplies: 3Last Post: 29th May 2008, 20:26 -
MPEG 2 Conversion to DV Video ruins aspect ratio
By dyoungiii in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 31st Jul 2007, 19:59
