Hey.
I need some assistance ..
I am trying to transfer some AVCHD video of a show I've recorded on my Panasonic HDC-SD700 videocamera. I wanna edit it in Premeiere Pro CS4.
The transfer proces worked fine with the program HD Writer AE 2,1. It placed 3 *. m2ts files in a folder.
- I recorded the whole show, continusly. About an hour..
(It only makes the files on the SD card 4 GB in size, so that they are compatible with most file systems).
The problem shows up, when I import the 3 files to my timeline in Premiere Pro.. I get a dropout of the sound and video, in the junction of the files. - When it goes one file to the next..
The odd part is that if I play the video from inside the HD writer program, it all plays seamlessly, without any dropouts.. - And the same if I play the video directly from my camera.
What do I do wrong?
The best would be to end up with just one file, that I could import into Premiere..
I hope someone knows what to do.
Thanks in advance.
HelionFilm
You could try join the m2ts files with tsmuxer and then import it premiere pro.
Thanks for the reply. I'll try that. Hope it works
- I'll get back with the result.
Kent. -
No, thats right. But in my case, it is olso there when I render the footage.
- I'll try the joyning shortly, to see if that sorts it out.
Premiere CS4 can't import AVCHD
By cheerful in forum EditingReplies: 24Last Post: 6th Mar 2012, 10:01 -
AVCHD Editting Premiere CS4
By AntAskew in forum EditingReplies: 7Last Post: 13th Jan 2011, 06:12 -
AVCHD EDITING IN Adobe Premiere CS4
By Don Man in forum EditingReplies: 10Last Post: 4th Jun 2010, 15:41 -
AVCHD and premiere pro cs4 demo!
By crossbrand in forum EditingReplies: 8Last Post: 7th Jul 2009, 12:19 -
Exporting AVCHD from Premiere Pro CS4
By jodal in forum Video ConversionReplies: 14Last Post: 29th May 2009, 07:12
