Can anyone recommend software I can use to strip out the audio (or mute the audio) of a video clip (any format) and SAVE the video portion? I have used RealPlayer Converter to strip and save audio from video clips but it doesn't work for retaining the video without the audio. Someone suggested I use QuickTime Pro but I've been having problems with codec plug-ins and was hoping something simpler was out there I coiuld use. Thanks in advance for your help!
thanks to Baldrick for your help. The program suggested did just what I needed!
how to convert and save audio & video files? how large of a HD?
By speone in forum Newbie / General discussionsReplies: 2Last Post: 15th Feb 2012, 13:55 -
brighten only a portion of a video?
By magnumpy in forum EditingReplies: 1Last Post: 23rd Dec 2011, 00:00 -
Can I save a Video/Audio being played on WMP/VLC/KMPlayer?
By ConverterCrazy in forum Newbie / General discussionsReplies: 2Last Post: 12th Jul 2011, 00:27 -
Removing more than one portion of a video at once.
By M Bruner in forum EditingReplies: 2Last Post: 21st Nov 2008, 04:17 -
edit only a portion of audio in video?
By shun in forum AudioReplies: 1Last Post: 7th Aug 2008, 19:11
