Hello guys... Recently I found that the hardsubbed subtitles can be stoled by using one program. Have you any idea how i can protect my subtitles from stealing? Any program or trick?
I don't know if there is has same topic with my but search don't workSo sorry if i repeat the question that someone else had ask.
Not possible. And an OCR software may make the task less difficult,How to protect subtitles from stealing
but it's not "mandatory". If one can simply read the subtitles,
then these can always be copied manually.
Put a copyright notice as the first subtitle.
But really, any attempt to make them less "copyable" will make them illegible to humans as well as OCR.
Protect computer files
By alintatoc in forum ComputerReplies: 3Last Post: 29th Sep 2009, 13:26 -
Can I copy protect my DVDR's
By 557953 in forum DVD RippingReplies: 5Last Post: 15th Jun 2008, 18:41 -
protect after/before authoring
By pcb in forum Newbie / General discussionsReplies: 8Last Post: 8th Mar 2008, 01:16 -
How do I copy protect a dvd?
By goheadtry in forum Newbie / General discussionsReplies: 5Last Post: 2nd Dec 2007, 18:22
