  1. Toast?
    Oct 2010
    Niagara Falls, Canada
    Don't know too much about video cables yet. Wondering if there's a trusted site I can order a couple of these.
    I have a quad screen splitter that is 6pin Inputs, but the preview feeds out the mixer are BNC.
    I need somewhere legit to order from, and i saw some pictures online of the cable and it always has two bnc cables coming out of it. Wondering why that is??
    thanks!
    nathan
  2. More info on the hardware would be helpful; what sort of inputs on that splitter, RF or some sort of line-level signal (RTFM)? I'll just say a BNC connector is used for an RF signal and I can't imagine what kind of video connector has 6 pins other than a proprietary one. If it's proprietary, I doubt you'll find a third party supplier for it.
    You could try asking the guys at Nutech on Nielsen between Welland ave and the QE in St Kitts; they deal with video stuff.
  3. Toast?
    Oct 2010
    Here`s the info for both pieces of gear...
    http://www.mito-oem.com/product.php?id=CB104S
    Power Supply DC IN 12V-24V Power Consumption 200mA (quad box only, no cameras)
    Video In (1) RCA
    Audio In (1) RCA, mono
    Camera Inputs (4) 6 pin mini DIN
    Monitor Output (2) Composite Video RCA
    Audio Output (2) for each monitor
    Thats what im looking at puchasing to have multiple previews on a single monitor.
    The mixer i will be using uses BNC for its preview outs...
    http://www.roland.com/products/en/V-440HD/index.html
    SD InputS-Video (Y/C) Preferential x 4 : 4 pin mini DIN type (Y: 1.0 Vp-p, C: 0.286 Vp-p, 75 ohms)
    Video (composite) x 4 : BNC type (1.0 Vp-p, 75 ohms)
    HD/RGB Input * BNC Type or D-sub Type are In/ThruOut Use combinedly BNC Type x 4 : HD: Y/Pb/Pr (1.0 Vp-p, 75 ohms, TriLevel Sync), RGB:R/G/B (0.7 Vp-p, 75 ohms), H (5VTTL), V (5VTTL)
    D-SUB 15pin Shrink Type x 4 : HD: Y/Pb/Pr (1.0 Vp-p, 75 ohms, TriLevel Sync, RGB:R/G/B (0.7 Vp-p, 75 ohms), H (5VTTL), V (5VTTL)
    SD OutputPGM S-Video (Y/C) : 4-pin mini DIN type (Y: 1.0 Vp-p, C: 0.286 Vp-p, 75 ohms)
    PGM Video (composite) : BNC type (1.0 Vp-p, 75 ohms)
    Preview (composite) : BNC type (1.0 Vp-p, 75 ohms), OSD Menu Output
    HD OutputPGM Component HD : BNC type x 2 (1.0 Vp-p, 75 ohms, TriLevel Sync)
    Preview Component HD : BNC type (1.0 Vp-p, 75 ohms, TriLevel Sync), OSD Menu Output (selectable Display
    I`ll give that shop a call next business day as well. thanks!
    Oct 2005
    666th portal
    those 6 pin inputs are for security type cameras. it's composite video and power in one cable. you can get 6pin to rca composite cable connectors and then also buy rca composite to bnc connectors. try amazon.
  5. Toast?
    Oct 2010
    really. I didn`t know that it carried the comp video and power in the same cable.
    Now can all three wires of a Composite (that`s the three wire cable right?) cable go to a single BNC connection at the other end of the cable?
  6. Banned
    New York, US
    Composite video cable is a single wire. It's actually a coax with an RCA connector. The other two wires are for audio (and both of those wires are also coax, with RCA connectors). RF cable is the same type wire (coax) with RF connectors.
    You can try sites that specialize is cables, connectors, adapters, etc., such as monoprice or someone like http://www.cablestogo.com/categories.asp?cat_id=881004.
