I typically create my VCD's with menus using TMPGEnc for the encoding and EZCD deluxe 4.XX for the burning. I have nice start up screens and a cool menu to access certain clips. The Apex 500W seems to play some discs while it will crash playing others. Everything remains the same as far as the creation process goes... encoder, burning software, media... all the same.
Anyone else run into this situation?
Nope I had an apex 660 and it played everything I threw at it, but I used Nero for menus
Paul,
I have had problems with VCD with menus on my Apex 500w. I tried using Nero to make the menus. It didn't crash, just played the movies all screwy.
So... is it just the menus that the player doesn't like? If I made a straight VCD without menus would the disc play OK?
Thanks--
Paul B -
Paul,
From my experience yes. If you just leave out the menus the vcd should play just pefectly. I just use the tracc selection as my menu system now
Some silent DVD menus won't work on Toshiba Blu-ray player
By denali in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 7th Feb 2012, 07:04 -
VCD cannot play in PC but can play in DVD player
By avatar123 in forum Authoring (VCD/SVCD)Replies: 28Last Post: 3rd Jan 2011, 17:32 -
Custom menus will not play back
By janlafata in forum Authoring (DVD)Replies: 3Last Post: 1st Jan 2009, 01:26 -
Help! Apex 5131 Will Not Play DVD
By NautTboy in forum DVD & Blu-ray PlayersReplies: 2Last Post: 24th Dec 2007, 12:33 -
Avid Lquid 7 menus..play chapter and play all
By cheesypuffs in forum Newbie / General discussionsReplies: 3Last Post: 24th Aug 2007, 02:34
