So i have a 2.0 PCM track that is currently from a 24fps Blu-ray and I'm trying to convert it to 23.976 to sync it up to something else.
Is there an easy way to do that? I find a lot of articles on PAL to NTSC conversion (and vice versa) but nothing on this type of conversion.
I have Adobe Audition, if that helps. I'm not sure what to put into the Stretch properties in order to get the right length.
Thanks!
Yes, that is the exact value. 23.976 is short for 24000/1001, or 23.976023976023976.... It's possible someone used 23.976 instead though. In that case the change would be 0.1001001..., but I don't know if you would notice the difference. Also keep in mind that different releases may have different amounts of junk at the start and end or have different cuts of the film (add or cut scenes).
Note: Make sure you're actually starting from a true 24fps source, as MANY BD titles are 23.976 (24000/1001) to start with.
Convert 30fps to 24fps skipping every 5th frame?
By DragonQ in forum EditingReplies: 7Last Post: 29th Jan 2011, 04:11 -
24fps video with 23.976fps audio
By brijazz in forum Video ConversionReplies: 1Last Post: 9th May 2010, 08:43 -
stretching 25fps audio to 24fps with mkvmerge
By deejay.2001 in forum AudioReplies: 0Last Post: 26th Feb 2010, 12:29 -
Audio adjustment for 25fps to 24fps
By ranosb in forum Video ConversionReplies: 29Last Post: 12th Aug 2009, 21:17 -
How to convert clips from 24fps to 16fps
By denti alligator in forum Video ConversionReplies: 9Last Post: 20th Oct 2007, 00:40
