Hi everyone,
You all seem like a knowledgeable bunch and I'd love some help please!
I've got a Samsung Recordable DVD player and would like to be able to use it to record Sky TV (cable TV here in New Zealand). I've been using the recorder to simply play DVDs with no worries but can't get it recording Sky.
Could someone please have a go at explaining what I need to connect? I wonder if I need a splitter or extra cables?
Happy to give more specific info, just don't know what to tell ya
Thanks very much!
Welcome sarahholland
More info on that samsung ... specify model (we can use this to determine input / ouputs the unit has)
If the Sky TV box has av output .. you'd normally connect this to the recorders av input ... and have the recorders av output returned to tv input.
Simply turn tv on and select av input channel you would normally use to view dvd's ... then on the recording unit select the required source input and Sky TV should appear ... from there you should be able to record .
The only question is if any channels carry a signal which prevents copying / recording ... normally premium channels do.
Problem connection HDD to TV
By WinSpecToR in forum DVB / IPTVReplies: 8Last Post: 19th Feb 2012, 13:16 -
Connection setup for a STB and HDD recorder
By garyasta in forum DVD & Blu-ray RecordersReplies: 1Last Post: 8th Mar 2011, 23:32 -
Copying from standalone hdd recorder's hdd to pc hdd
By flez in forum ComputerReplies: 7Last Post: 6th Dec 2010, 07:17 -
Sky+ usb connection
By shedman in forum Capturing and VCRReplies: 3Last Post: 19th Jul 2008, 12:26 -
Sky+ to External HDD
By fubsy in forum Newbie / General discussionsReplies: 1Last Post: 9th Jul 2007, 14:17
