  1. I am tryng to enable the VOB2MPG Pro S/W on my new PC and everytime I try to get a new reg code I get this error.....please help.
    Server Error in '/' Application.
    A network-related or instance-specific error occurred while establishing a connection to SQL Server. The server was not found or was not accessible. Verify that the instance name is correct and that SQL Server is configured to allow remote connections. (provider: Named Pipes Provider, error: 40 - Could not open a connection to SQL Server)
    Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
    Exception Details: System.Data.SqlClient.SqlException: A network-related or instance-specific error occurred while establishing a connection to SQL Server. The server was not found or was not accessible. Verify that the instance name is correct and that SQL Server is configured to allow remote connections. (provider: Named Pipes Provider, error: 40 - Could not open a connection to SQL Server)
    Source Error:
    An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
    Stack Trace:
    [SqlException (0x80131904): A network-related or instance-specific error occurred while establishing a connection to SQL Server. The server was not found or was not accessible. Verify that the instance name is correct and that SQL Server is configured to allow remote connections. (provider: Named Pipes Provider, error: 40 - Could not open a connection to SQL Server)] System.Data.SqlClient.SqlInternalConnection.OnErro r(SqlException exception, Boolean breakConnection) +4849015 System.Data.SqlClient.TdsParser.ThrowExceptionAndW arning(TdsParserStateObject stateObj) +194 System.Data.SqlClient.TdsParser.Connect(ServerInfo serverInfo, SqlInternalConnectionTds connHandler, Boolean ignoreSniOpenTimeout, Int64 timerExpire, Boolean encrypt, Boolean trustServerCert, Boolean integratedSecurity, SqlConnection owningObject) +4862333 System.Data.SqlClient.SqlInternalConnectionTds.Att emptOneLogin(ServerInfo serverInfo, String newPassword, Boolean ignoreSniOpenTimeout, Int64 timerExpire, SqlConnection owningObject) +90 System.Data.SqlClient.SqlInternalConnectionTds.Log inNoFailover(String host, String newPassword, Boolean redirectedUserInstance, SqlConnection owningObject, SqlConnectionString connectionOptions, Int64 timerStart) +342 System.Data.SqlClient.SqlInternalConnectionTds.Ope nLoginEnlist(SqlConnection owningObject, SqlConnectionString connectionOptions, String newPassword, Boolean redirectedUserInstance) +221 System.Data.SqlClient.SqlInternalConnectionTds..ct or(DbConnectionPoolIdentity identity, SqlConnectionString connectionOptions, Object providerInfo, String newPassword, SqlConnection owningObject, Boolean redirectedUserInstance) +189 System.Data.SqlClient.SqlConnectionFactory.CreateC onnection(DbConnectionOptions options, Object poolGroupProviderInfo, DbConnectionPool pool, DbConnection owningConnection) +185 System.Data.ProviderBase.DbConnectionFactory.Creat ePooledConnection(DbConnection owningConnection, DbConnectionPool pool, DbConnectionOptions options) +31 System.Data.ProviderBase.DbConnectionPool.CreateOb ject(DbConnection owningObject) +433 System.Data.ProviderBase.DbConnectionPool.UserCrea teRequest(DbConnection owningObject) +66 System.Data.ProviderBase.DbConnectionPool.GetConne ction(DbConnection owningObject) +499 System.Data.ProviderBase.DbConnectionFactory.GetCo nnection(DbConnection owningConnection) +65 System.Data.ProviderBase.DbConnectionClosed.OpenCo nnection(DbConnection outerConnection, DbConnectionFactory connectionFactory) +117 System.Data.SqlClient.SqlConnection.Open() +122 www.svcd2dvd.com.Users._default.GetProductsForUser() in G:\2backup\www.svcd2dvd.com\htdocs\Users\default.aspx.cs:224 www.svcd2dvd.com.Users._default.btnSubmit_Click(Object sender, EventArgs e) in G:\2backup\www.svcd2dvd.com\htdocs\Users\default.aspx.cs:139 System.Web.UI.WebControls.Button.OnClick(EventArgs e) +111 System.Web.UI.WebControls.Button.RaisePostBackEven t(String eventArgument) +110 System.Web.UI.WebControls.Button.System.Web.UI.IPo stBackEventHandler.RaisePostBackEvent(String eventArgument) +10 System.Web.UI.Page.RaisePostBackEvent(IPostBackEve ntHandler sourceControl, String eventArgument) +13 System.Web.UI.Page.RaisePostBackEvent(NameValueCol lection postData) +36 System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Thanks for the headsup. I have raised a ticket with my service provider and they are on the case. In the meantime if you email me then i can send you a code etc manually...
    Jun 2006
    ChrissyBoy,
    You have a PM
