I picked up a pctv HD mini stick 80E (USB2 digital ATSC/ClearQAM device) at Radioshack for about $32 (incl. tax)... was too cheap to resist.
It came with V5.4 of TVCenter - I installed it in Trial mode and it looked ok.
then on their website I saw there is a V6.4 which claims to require less resources (at cost of not being able to record direct to DVD or encode on the fly) and is hopefully more stable.
I installed that on a second PC in trial mode but found that the AC3 audio is disabled until you register/activate (I am still a bit confused about whether there is a charge to Activate it - I suspect not.). Also it looked like the EPG programming guide was not fully functional without activation. I don't suppose I will use the Distan facility to stream to a remote device.
Does anyone know how these two versions of TVCenter compare? Do I lose out in some way using the newer version? Am I better off using the Vista media center (I have Ultimate and Home Premium versions on two PCs)
Also the EULA seems to state that you can only install on one PC. Is that enforced through the activation key? In a family situation I would like to be able to switch the TV stick between PCs depending on convenience/need.
Any info welcomed!
Results 1 to 1 of 1
What does one do about multiple DVD versions?
By takearushfan in forum Newbie / General discussionsReplies: 6Last Post: 24th Nov 2011, 01:57 -
transfer programs across xp installs (on 2 different hard drives)
By greymalkin in forum ComputerReplies: 2Last Post: 17th Nov 2009, 06:11 -
Unrated & Theatrical versions on One Disc
By jah711 in forum Blu-ray RippingReplies: 4Last Post: 16th Jan 2009, 09:43 -
Problem with FFmpeg with versions 2728 & 2733
By Randalliser in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 5th Jul 2007, 03:40 -
DVD has (2) versions WS & std, how to back up only WS ver ?
By theewizard in forum DVD RippingReplies: 9Last Post: 6th Jun 2007, 17:00
