first time i have ever had this problem
its not the size as its 900mb and i have tv show files on there over 90gig!
i usually go to my hard drive find the file i want and drag and drop to external hard drive
this one movie just wont move
it plays fine on the computer but i want it on hard drive to use WD media player
any ways around this? will feel stupid if its something simple but like i said never encountered this before
Just basic, but have you rebooted and tried it again? I wondering if some software is trying to use the file and preventing the transfer.
sounds stupid but i only reboot/turn my laptop off once every few days as 50% of the time the screen doesnt come back on when turning it back. have to let it sit there for hours till out of no where the screen will come back on and i can use it again.
but yeah i should try rebooting tho cant see why any other software would be using it.
when i try to move it, it doesnt stop me, what it does is instead of saying for example tranferring file 11min to go it just says copying file but nothing happens -
Try the free program ... Unlocker 1.89 ... there are newer versions but version 1.90 wants to push advertisements
Are you trying to move or copy the video file? If you're trying to move, try copying instead.
copying
it has now worked after turning off computer
weird as it wasnt opened in any other program
Transferring AVI to Sony Hard Drive recorder - Advice please
By porty in forum Video ConversionReplies: 13Last Post: 20th Dec 2009, 03:33 -
Transferring files from hard drive to Zune
By maroonx in forum Portable VideoReplies: 1Last Post: 25th Jul 2008, 22:30 -
Replace Dead Hard Drive From DVR 533HS With Working Hard Drive From DVR 640
By gordo1811 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 12th Dec 2007, 15:58 -
Transferring video to hard drive.
By vid83 in forum Newbie / General discussionsReplies: 16Last Post: 11th Dec 2007, 21:41 -
Is It Possible to Make Multiple Drive Images on One External Hard Drive
By drstew in forum ComputerReplies: 17Last Post: 24th Nov 2007, 08:47
