I've used various software to convert the file to different sounds types but it's always out of sync.
I tried burning the file onto DVD, and that was out of Sync also.
I've watched the film on the PC and the audio is fine, it's just on the PS3 that it does't work. I'm pretty bummed because I want to watch it with my family.
Any advice on how to get it to work? Avidemux just isn't working.
Try reprocesssing the audio using virtualdub. Set the video to "direct stream copy" and audio to "full processing mode" and see if that fixes it. Else you might try running the file through divfix and check test that first.
AnyDVD to TsRemux , works but no sound on ps3 ?
By krohm in forum Blu-ray RippingReplies: 8Last Post: 5th Aug 2009, 06:46 -
Jerky Picture and Sound on PS3
By det66 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 11th May 2009, 00:11 -
Jerky Picture and sound on PS3
By thumper66 in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 5th Mar 2009, 11:51 -
PS3 Sound Help
By Nitro89 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 19th Feb 2009, 17:41 -
PS3 Video 9 - .AVI to PS3 - Settings
By dec60228 in forum Video ConversionReplies: 0Last Post: 22nd Feb 2008, 14:48
