It's such a long time since I don't do this that I got rusty on how to.
I have an mkv file that I wish to convert to m2v so I can do a DVD from it. The best tool for that is Avisynth, of course.
The file is 1200x720 (1.667) with 23.976fps, according to Mediainfo.
From the time I did such conversions, the script I used for such files was:
FFMpegSource2("i:\file.mkv")
Spline36resize(672,480)
addborders(24,0,24,0)
I loaded this script in AvsP and they seem to load fine.
But when I load them in HCenc the frame rate is changed to 23.8092. A warning advice says there's a resolution/framerate mismatch.
What am I doing wrong?
Carlos
Results 1 to 19 of 19
what does info() report the fps is ?
some ffms2 versions get the fps slightly off
you can correct it by adding
AssumeFPS(24000,1001) -
ffms2, the source filter sometimes gets the fps wrong, but the frame count is correct
assumefps changes fps without changing framecount
http://avisynth.org/mediawiki/AssumeFPS
if you use info() and preview the script, it will tell you what ffms2 "thinks" the fps is. If it's NOT 23.976, then use AssumeFPS. If it IS 23.976, then the problem is after the script (maybe HCenc) . I suspect problem is ffms2 -
Sorry, this is the complete text report:
General
Complete name : I:\file.mkv
Format : Matroska
File size : 4.37 GiB
Duration : 1h 51mn
Overall bit rate : 5 630 Kbps
Encoded date : UTC 2011-04-12 21:06:52
Writing application : mkvmerge v4.6.0 ('Still Crazy After All These Years') built on Mar 10 2011 02:50:32
Writing library : libebml v1.2.0 + libmatroska v1.1.0
Video
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Muxing mode : Container profile=Unknown@4.1
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 51mn
Bit rate : 5 070 Kbps
Nominal bit rate : 5 182 Kbps
Width : 1 200 pixels
Height : 720 pixels
Display aspect ratio : 1.667
Frame rate : 23.976 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.245
Stream size : 3.93 GiB (90%)
Writing library : x264 core 114 r1924 08d04a4
Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=18 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=5182 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Audio
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Duration : 1h 51mn
Bit rate mode : Constant
Bit rate : 448 Kbps
Channel(s) : 1 channel
Channel positions : C
Sampling rate : 48.0 KHz
Stream size : 356 MiB (8%) -
Thanks Poison. Now the file worked fine.
Yes, the size looks correct. It doesn't look cropped or anything. It shows black borders on the sides, as it should being slightly smaller than 16:9 (1.777). -
but are the black borders from the source file, or from the media player using a 16:9 display ?Yes, the size looks correct. It doesn't look cropped or anything. It shows black borders on the sides, as it should being slightly smaller than 16:9 (1.777).
If the source file looks correct (circles look like circles, not ovals, no borders in the source), then fitcd says the resize should be 654x480, not 672x480
Spline36resize(656,480)
AddBorders(32,0,32,0) -
As I said before, I am a little bit rusty with conversions to DVD. My fault because it's quite necessary for my line of work (video production).
I use HCenc 0.23, and now I see that there's even a o.26 beta release.
Should I go for the 26, stick to my 23 or get the 25?
What got me curious is that the 23 only uses just one core of my CPU for processing, and perhaps it might cut time in half by using both.
The other versions use all cores? -
We had a similar discussion some time ago, about the size suggested by Fitcd and the one I wanted to use, based on my calculations.
That time I was right, and I did several tests to be sure about that.
Now I in the middle of the conversion, so when it's finished I will check on the results again and even do a short test with FitCD's data on a circle at the beginning of the film.
Tomorrow I will get back on that. -
Newest HCEnc is fine, should be using more than 1 core unless you have other bottlenecks
The AR depends if you're basing calculations based on 704width +/- letterbox vs. 720width . There is lot of disagreement on which one is "correct" for DVD
The 672 value would be "correct" based on 720 width assumption (32:27)
672/480 x 32/27 = ~1.659
The 656 value would be "correct" based on 704 width assumption (40:33)
656/480 x 40/33 = ~1.657 -
You mean TMPGenc Xpress 4.0?
I have used it, but Avisynth is a LOT better. Final quality is much closer to original HD file than with TMPGenc. -
My calculations were based on the 720 width.
Just now I did the test using the 656 value and compared it with former 672 value.
It's unsaid than on the 656 value, the side borders are larger, of course.
On 656 test, the circle at the beginning (Criterion) is vertically egg-shaped. In the 672 test, it's undistorted.
I can try capturing the circles for you to see.Last edited by carlmart; 15th Apr 2011 at 07:57.
Well, I was sure about the 720 value because I had been using it and seeing circles on my plasma, and they reproduced as they should.
Particularly Criterion's and MGM's. Paramount's is a bit oval vertically.
Converting DVD to MKV file
By thearm in forum DVD RippingReplies: 5Last Post: 11th Nov 2009, 08:34 -
Converting MKV file to DVD burnable format
By ryoden in forum Video ConversionReplies: 6Last Post: 29th Jul 2008, 14:54 -
making a compliant resolution mpeg2 file from a non-compliant .mkv file
By dwisniski in forum Video ConversionReplies: 1Last Post: 7th Mar 2008, 07:49 -
question about converting mkv file to DVD
By jimdagys in forum Video ConversionReplies: 11Last Post: 7th Feb 2008, 20:00 -
Converting MKV to a smaller MKV file
By Boriskali in forum Video ConversionReplies: 3Last Post: 1st Dec 2007, 07:07
