I downloaded Aften to encode a AAC file to AC3 so I could burn it to a DVD. However, the sound was distorted during playback from my DVD. The sound is fine when played on my computer, however. Am I doing something wrong? I set the quality to 240 (-q 240). The AAC file has six channels, by the way.
This is what VLC says about the AC3 file:
Code:Type: Audio Codec: A52 Audio (aka AC3) (a52) Channels: 3F2R/LFE Sample Rate: 48000 Hz Bitrate: 640 kb/s
640 kb/s AC3 is not compliant for DVD (although some DVD players might be able to play it)
You should specify CBR bitrate e.g. -b 448
Question about hd audio in wmv hd - is it ac3/dts compatible?
By yoda313 in forum Blu-ray RippingReplies: 4Last Post: 12th Mar 2009, 17:12 -
Vista 64bit compatible encoder
By tommcd64 in forum Video ConversionReplies: 2Last Post: 18th Feb 2008, 08:21 -
PS3 + ac3/5.1 audio = does a compatible container exist for what i want?
By domerdel in forum ffmpegX general discussionReplies: 0Last Post: 21st Aug 2007, 16:38 -
Is Cinema Craft Encoder compatible with Windows Vista?
By cormor in forum Newbie / General discussionsReplies: 8Last Post: 8th Aug 2007, 15:51 -
AC3 / DivX Compatible Players
By nordicgreen_8 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 14th May 2007, 08:35
