Will MVtools work on my Athlon 1800+ (no sse2)
can't seam to find the requirements for this plugin
i just want to convert an handheld camera shot
from 30 to 60 fps to feed to deshaker (lots of panning and fast motion)
i don't want to just double up the frames , just interpolate the missing frame
lots of avisynth plugins require sse2
and i want to find a workaround
thanks for your time , have a great day
my source is in .asf format
Results 1 to 21 of 21
I don't think it's a requirement, just makes it process faster
what error message are you getting?
what camera shoots directly to .asf .wmv ?? -
it's not my camera but a friend's ; i think it's a cannon but i'm not really shure
what would be the ideal script for this task ?
i just wanted to know before doing anything -
General
Complete name : C:\...FNM_Jam06.ASF
Format : Windows Media
File size : 616 MiB
Duration : 24mn 11s
Overall bit rate : 3 558 Kbps
Maximum Overall bit rate : 3 731 Kbps
Encoded date : UTC 1970-01-01 00:00:00.000
Video
Format : MPEG-4 Visual
Codec ID : M4S2
Codec ID/Hint : Microsoft
Description of the codec : mpeg4z
Duration : 24mn 11s
Bit rate : 3 364 Kbps
Width : 640 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate : 30.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.365
Stream size : 582 MiB (95%)
Audio
Format : ADPCM
Codec ID : 2
Description of the codec : adpcm_ms
Duration : 24mn 11s
Bit rate : 44.1 Kbps
Channel(s) : 1 channel
Sampling rate : 11.025 KHz
Bit depth : 4 bits
Stream size : 7.63 MiB (1%) -
What is your end goal ? PC playback? or something like DVD ?
It matters, because 30.0 fps is different than 29.97 fps (30000/1001) , and some devices and standard hardware require the proper 30000/1001
Also you have mono audio, does that matter to you? You can make it "fake stereo" by copying the channel
Motion interpolation has a lot of side effects - objects morph and you get edge dragging. It can look very bizarre. Some types of content are interpolated better than others -
lots of end goal , both dvd and web (facebook and youtube) but mostly a good mpeg2
will try to mix it later with another camera shot (another format)
i will keep the audio format to mono ,
but for now i'm just preparing the sources if i can put it this way ..
ideally i'll go from 30 (.asf) to 60fps (.avi) and end up with 29.97(mpeg2) at the end
i just basically want a lot smoother playback from deshaker (or another tool !)
I taught MVtools was used also for noise reduction ?
if it introduced artifacts well i'll pass ... -
ok, but for DVD you need to make it compliant - frame size and fps need to be "fixed" at some point in your workflow, and the audio is not compliant either - you would need to fix sampling rate
60.0 fps isn't compliant, and 60 to 29.97 implies that you are making it 59.94i (interlaced ?) because 59.94p isn't complaint with DVD or youtube etc... Youtube will only accept upto 30.0p
MVtools is used in a lot of filters for different purposes
The motion interpolation will always introduce artifacts of some sort. You're generating "inbetween" frames. On some types of content, it's barely noticable, on others it's very horrible
You can try it out the documentation gives you a simple variation (just copy & paste it). And there are several variations on interpolation scripts you can try as well -
i'm thinking that a better frame rate doubling would give me better and smoother results from deshaker
a good feed for deshaker = better file for my mpeg2 encoder
avisynth script to virtualdub (deshaker) =30 to 60 fps
and then 60fps file to maybe HC via another script (60 to 29.97 (30 fps drop frame))
that's why i'm posting in the newbe forums
the audio will be muxed at the end -
It might be better , it might be worse, or anything in between. It really depends on the type of content
Here is a simple script for 2x (so 60.0 FPS if your source was 30.0 FPS) , for video only using the older mvflowfps from mvtools 1.x
source=FFVideoSource("video.asf")
backward_vec = source.MVAnalyse(overlap=4, isb = true, pel=2, search=3, idx=1)
forward_vec = source.MVAnalyse(overlap=4, isb = false, pel=2, search=3, idx=1)
source.MVFlowFps(backward_vec, forward_vec, num=2*FramerateNumerator(source), \
den=FramerateDenominator(source), idx=1)
If you wanted to use mflowfps from mvtools 2.x
super = source.MSuper(pel=2)
backward_vec = MAnalyse(super, overlap=4, isb = true, search=3)
forward_vec = MAnalyse(super, overlap=4, isb = false, search=3)
source.MFlowFps(super, backward_vec, blend=false, forward_vec, num=60, den=1)
The results will be similar in terms of artifacts -
i'll try that latter on this evening
got to go to work !
and thank you for your input -
if it was cut incorrectly , you can get that error with ffms2
try another source filter dss2 , it comes with haali media splitter package. Put avss.dll in plugins folder
DSS2("video.asf") -
l'll try first to make it seekable with asftools if that does not work i'll try it
i did both asftools repair and the dss2 thing my file is now being analysed 20 hours for a 25 min clip ouch !
i did the script with MEgui it crashed while doing it but i managed to save the script anywayLast edited by smartel; 14th Apr 2011 at 23:19.
i'm now encoding
the preview in virtualdub looks good (xvid bitrate = 5000)
i'm still at 60 fps , should i have done it at 29,97??
the result of this will be dvd .. framerate convertion will be the next step
gives me time to read a little ..
read about MotionProtectedFPS from masktool (SalFPS3!??)
am i dearching too far ?
i'm aiming for smootest play
script used :
LoadPlugin("C:\Documents and Settings\Steve\Bureau\MeGUI_1989_x86\tools\avisynt h_plugin\avss.dll")
LoadPlugin("C:\Documents and Settings\Steve\Bureau\MeGUI_1989_x86\tools\ffms\ff ms2.dll")
DSS2("C:\Documents and Settings\Steve\Bureau\FNM\Nouveau dossier\Nouveau dossier\FNM_Jam06.lch.adv.ASF").AssumeFPS(30.000)
source=DSS2("FNM_Jam06.lch.adv.ASF")
ConvertToRGB
i did it with no audio ...maybe i should have done it so that video and audio match in virtualdub ... -
You might have problems with sync, because many .asf/wmv files are variable frame rate and variable sample rate.
You can try this instead
source=DirectShowSource("video.asf", fps=30, convertfps=true, audio=true)
ConvertToRGB
This will include the audio and (hopefully) be in sync
Keep it at 60fps until you've finished exporting from deshaker and vdub , then do the framerate conversion and re-interlacing, and resample the audio -
another day (or 2) of encoding for me ... i need one more pc
and thx again for the input -
doesn't MVtool have it's own stabilisation capability ?
deshaker's results are so so
MVtools/MVtools 2 frame doubling problem
By Gnodab03 in forum Software PlayingReplies: 2Last Post: 3rd May 2011, 04:14 -
AviSynth working with Y8 uncompressed AVIs and MVTools motion interpolation
By a1s2d3f4 in forum Newbie / General discussionsReplies: 6Last Post: 10th Nov 2010, 21:32 -
Few questions regarding LCD tv... that will lead to more questions :)
By ohlookyhere in forum DVB / IPTVReplies: 16Last Post: 15th Aug 2010, 15:50 -
MVTools & AVISynth script question with FFDShow
By Gnodab03 in forum Software PlayingReplies: 7Last Post: 8th Jan 2010, 19:05 -
Powersupply questions and fan questions
By yoda313 in forum ComputerReplies: 39Last Post: 8th Sep 2008, 18:08
