Hello to all,
I what to be able to watch NTSC d.v.d's on my ewuropean d.v.d. player LG DVX172.
but I'm having problems with the instructions.
Can someone please tell me that the hell Open sled. means and how can I go about locating, modifying or opening it?
	Thanks. All I need now is to know how to burn this file! http://rapidshare.com/files/14530611/Zoran.zip.html
 I downloaded, opened and burned it, but the d.v.d. didn't recognize it.
 I followed these instructions to no avail: Region code hack posted by kelon, November 07 2006: Region code hack posted by kelon, November 07 2006:
 Power ON
 Wait until NO DISC is displayed
 Open sled.
 Key in 0 0 0 0 until a display showing regions comes up
 Input 0
 Press PAUSE
 Press OFF
 Remove from mains
 When you power up, will be region free
 Then, I downloaded the file, below:
 NOTE;
 Newer models may not accept due to a change made by Vaddis 882 chip.
  Region code hack posted by Andytai, February 02 2007: Region code hack posted by Andytai, February 02 2007:
 Regarding new chipset older hacks doesn't work.
 this one - works.
 Insruction inside archive
 Where am I going hidiously wrong?
	1) It's possible that you didn't burn the disc correctly or your player doesn't like the brand or type of media you used.
 2) The "NOTE" warns you that hardware changes may cause this to not work anymore and it's possible that you've got newer hardware that this doesn't work on.
	The last time I did this, I wrote it to a CD as mode 1 data.
 From the zip file, extract LG36868.IMG. Burn this file directly to the CD root and try again.
  Subtitle can't find with MKVextract & MKVtoolnixBy sanlocrip in forum SubtitleReplies: 2Last Post: 18th Mar 2012, 13:27
  Need to know to find & disable background processesBy Danae in forum MacReplies: 16Last Post: 11th Aug 2010, 23:23
  how 2 open mp4 & mkv video files in vdubBy naveenkrish in forum EditingReplies: 2Last Post: 19th Jun 2010, 23:14
  program to find out what type of audio & videoBy rtrimarchi in forum Newbie / General discussionsReplies: 2Last Post: 25th Jul 2009, 14:24
  Imported Film, Close, Open & Then It's Gone.By Fairy_xo in forum EditingReplies: 10Last Post: 11th Nov 2008, 14:30
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
