Hi all, I was authoring a DVD project in TMPGEnc Authoring Works 4 and added some subtitles (SRT). When I did the simulation, the subtitles were left aligned and were really large. I went back to edit the subs and the font was set at Tahoma, size 10, center align. But it still looks large and is left-aligned in the preview and the simulation. Will it look like that on DVD as well?
Also, due to the large size, the lines got cut off
like this
and the second line would continue like this.
What would be a standard setting for font size?
	Have you applied correct layout? http://tmpgenc.pegasys-inc.com/en/product/taw4_tutorial/taw4_tu_subtitle04.html
	I use TMPGEnc Authoring Works 4 and when I want to see how the DVD will look, I burn it to an DVD-RW to preview my project. I have never had a problem with adding subtitles. If it feels good, do it.
	I burned it onto DVD+RW to check and yes, the subs are just as large as in the simulation. I guess it's just a matter of changing the font size. Wondering why they have it set as default such a large font size. Thanks for the tips!
  My TMPGEnc Authoring Works 4 in window 7By sleung in forum Newbie / General discussionsReplies: 0Last Post: 11th Sep 2011, 20:54
  What is the different between TMPGEnc Authoring Works 4 & TMPGEnc 4.0 XPresBy c1steady in forum Newbie / General discussionsReplies: 0Last Post: 28th Apr 2010, 22:32
  TMPGEnc Authoring Works v.4.0.4.24 - AuthoringBy niteghost in forum Authoring (DVD)Replies: 8Last Post: 21st Jul 2009, 22:15
  export subtitles created/synched in Authoring WorksBy ecc in forum SubtitleReplies: 1Last Post: 21st Feb 2009, 19:44
  TMPGEnc Authoring Works 4 persian subtitlesBy k11984 in forum Authoring (DVD)Replies: 1Last Post: 11th Jan 2009, 05:26
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
