  1. i have almost 2 TB of various video files spread across four external drives and one internal drive. i'm worried that a hard drive failure is due to strike me at any time and i would lose files that i couldn't replace. what is the best - and cheapest - way to backup all these files?
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Um....more hard drive space?
    May 2001
    what more can you say
    CHEERS GARRY
  4. You can get 2 TB drives for as little as US$80 these days, both internal and external (USB). For example:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16822148579
    $79.99, free shipping
  5. Mod Neophyte redwudz's Avatar
    USA
    This is what I'm using for backup now: http://www.agestar.com/english/products/s2b3a.asp I have two 2TB Samsung hard drives set up as RAID 1. The RAID controller is in the drive box, a Silicon Image 5744. If one drive fails, you can hot swap a new drive in and be back up and running in a short time. I use the eSATA connection to my computer. The unit works very well and is quiet and compact. About $70US from: http://www.cooldrives.com/index.php/twodrsaiirac.html
    Feb 2008
    Buy a 2TB external hard drive and copy all the files.
  7. I generally try to have 3 copies of important files so buy 2 2tb drives and store one offsite.
