Hi Friends,
I have DVD-9 and I want to rip it to my HD using TMPGEnc Xpress then authoring it back to DVD-5 using TMPGEnc Authoring Work 4. I have tried many software but so far I found this one is the best quality for Video output. No matter what format I chosen it still give me almost 100% of output quality.
But the problem is that I can't get Audio to works right. I want 5.1 Channels but it always comes with 2 channels after I converted. I have tries all different format but it don't works.
My question is, Can TMPGEnc 4.7.7.307 XPress support output 5.1 Channels?
Below is one the format that I already tried to convert:
General
Complete name : J:\Terminator Salvation 2009\Terminator Salvation 2009.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 1.96 GiB
Duration : 1h 57mn
Overall bit rate : 2 380 Kbps
Encoded date : UTC 2011-02-15 18:49:49
Tagged date : UTC 2011-02-15 18:49:49
Video
Format : AVC
Format profile : Baseline@L3.1
Format settings, CABAC : No
Format settings, ReFrames : 1 frame
Codec ID : avc1
Duration : 1h 57mn
Bit rate mode : Constant
Bit rate : 2 072 Kbps
Width : 1 080 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 fps
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.089
Stream size : 1.70 GiB (87%)
Language : English
Audio
Format : AAC
Format version : Version 4
Format profile : LC
Format settings, SBR : No
Codec ID : 40
Duration : 1h 57mn
Bit rate : 310 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Stream size : 261 MiB (13%)
Language : English
Thanks in advanced for your help. I'm really appreciate if you introduce me some software that can does this job.
Why convert to mp4 first? You can import dvds directly in tmpgenc authoring works. Shrink with dvd shrink or dvd rebuilder instead.
Or is your mp4 the source? No, most converters can NOT convert 2 channel to 5.1 channel. -
Thanks for your help.
No my original source are on DVD9 so I converted it into MP4 by using TMPGEnc Xpress. I'm sure there is a 5.1 Channel on the DVD9 but I got only 2 channel output after I converted. No matter what format I choose I still get same result.
I used to burn this 2 channel output to DVD using TMPGEnc Authoring Works. When I play this DVD on my Sony Home Theater I found out that only the Front Left and Front Right speaker I can hear the sound comes out but other 4 speakers nothing. I already tried my original source on the same player it works I can hear the sound come from every speaker.
The reason I converted to MP4 because I want to take out everything from the original DVD. I just want to have only the main movie and one Audio (English language) and modify my own Subtitle in TMPGEnc Authoring Works.
I really don't care 2 or 5.1 channel now as long as I can get the sound as my original DVD is fine for me. I can't figure it out which software (TMPGEnc Xpress and TMPGEnc Authoring Works) is the case that cause the sound problem????
Any idea sir. Baldrick??? Thanks again for your help.
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 16:42 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 14:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
Help with output after editing with tmpgenc 4.0 xpress
By uka100 in forum EditingReplies: 2Last Post: 14th May 2008, 21:30 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07
