I orginal had a single .ts that is 2 hours long. I cut the last 45 minutes out (becuase audio went out of sync) and saved it as cl.ts. then took original .ts and cut the first 1 15 off and saved it with a 1500ms shift(as shift.ts) to the audio track which put it back in sync. then i used Avidemux to append the second (shift.ts) to the first (cl.ts) but when i used HDTV2DVD the mpg created did not carry the shift (that put audio back in sync) over to output. any help would be appreciated.
I figure frames where dropped in the orginal capture but i have been unable to recaputre the video from my DVR because i countiulay crash my computer with stream.sys errors and similar. not sure if i got lucky the first and now its just being difficult. (Windows vista)
Results 1 to 1 of 1
Seeking in Transport Streams(.TS)
By deepp in forum ProgrammingReplies: 0Last Post: 15th Jul 2010, 16:00 -
NO LFE channel in TS transport streams ?
By s1lenc0r in forum Video ConversionReplies: 1Last Post: 17th Apr 2010, 07:02 -
Joining transport streams ?
By NotSoEasy in forum DVB / IPTVReplies: 7Last Post: 3rd Jul 2009, 18:32 -
Converting Transport Streams to AVI
By RedPenguin in forum Video ConversionReplies: 3Last Post: 14th Apr 2009, 22:56 -
European transport streams
By branch in forum DVB / IPTVReplies: 26Last Post: 27th Mar 2008, 03:50
