Hello!
I hope someone can help me with this, I tried to search the forum, but there are so many resources that I got lost, I'm looking for something simple!
I need to crop some mpg2 video I recorded from the web, I mean I need to cut a little bit of the screen of all 4 sides because I recorded too much of it. I'm looking for something simple and easy, that won't change the original quality too much.
I have Ulead Videostudio and Cyberlink powerdirector. Also Adobe premiere... but it's too difficult for me.
I don't mind the program, I can use whatever you suggest me... I just need something easy because I'm not really good at it.
Thank you very much to anyone who will help me!
				Results 1 to 9 of 9
	You could try the freeware AviDemux. Under video filters, there is a crop option. That program is fairly easy to use.
 But a couple of things to be aware of. Cropping means you will have to re-encode the video. If it's MPEG-2, you can use the same format. You will lose some quality, but you could up the bitrate to lessen the loss. But that will also make the file larger.
 Second thing, if this video is going to go on a DVD, then it has to be a certain size to meet the DVD specifications.
 There are other video editors that can also do this. Some of our other members may suggest some.
 And welcome to our forums.
	One other thing - I believe I am correct in saying this - if you are going to crop Mpeg2 video which is interlaced then you MUST deinterlace first otherwise you will destroy your video - it will have interlaced artifacts
	Interesting comment since a while back I did this: program = Ulead Video Editor V7
 1. Started with a PAL source Mpeg2 4:3 video (720*576) upper field - did NOT deinterlace
 2. Cropped 72 lines top, 72 lines bottom (that is in multiples of 4)
 3. reencoded video to retain the 720*576 so I now had a 16:9 anamorphic DVD video upper field
 The resultant video was full of interlaced artifacts.
 However, if I deinterlaced and then performed steps 2 and 3 there were no artifacts in the finished video.
 Which begs the question. If the problem was not caused by failing to deinterlace then it must have been caused by the reencoding ???
	If your distribution video will be web/computer then you must/should deinterlace. Interlaced video is only for TV viewing.
  Looking for an easy way to crop videosBy Sperling_96 in forum Newbie / General discussionsReplies: 2Last Post: 3rd Oct 2011, 05:41
  Newbie Help Needed for making VideosBy stroke in forum Newbie / General discussionsReplies: 8Last Post: 6th Mar 2011, 08:42
  Crop videos playing on Windows Media PlayerBy kingshay in forum Software PlayingReplies: 2Last Post: 28th Nov 2010, 13:00
  Newbie: Can SVCD2DVD crop the MPEGs?By jrisch in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 10th Mar 2010, 14:21
  Sony Vegas 8 Pro Question - How to crop entire movie with multiple videos?By Mysteriouskk in forum Newbie / General discussionsReplies: 4Last Post: 5th Mar 2008, 20:50
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
