I have Camtasia 7. I will buy what is needed to finish my job, but as inexpensively as possible.
I have about 20 2-3 minute videos with "tips" for a church on reading out to chronically ill. What I want is (1) For someone to be able to put the DVD into the DVD player and have 2 options (a) to be able to watch the entire "movie" and have each section fade/transition between (b) for groups, like deacons to be able to click on "chapters" where they want to start so they could want 2 or 3 each meeting.
I need to be able to select where I want the selection/chapters to stop and start.
I've downloaded 3 trials of software and each one either does not have transitions or doesn't have a menu.
Anyone have a tip on what software would do this?
Hi
If I understand your question correctly, TMPGEnc DVD Author, or TDA, can get the job done. The menus have a PLAY button, by default, that will play the entire video.
You can split each video at the place you want your chapters to be. This, for example, will make 1 clip 2 separate clips. A thumbnail will be placed on the menu for each split as well as at the beginning of each clip (by default, each clip has a chapter point at it's beginning.) And for each clip start and each split point you can place a transition.
Hope this helps
Brainiac
Edit: Instead of splitting, you can just move the CTI to where you want to place the chapter point and then press the chapter point button.Last edited by Brainiac; 13th Apr 2011 at 15:51.
GUI for dvdauthor:
https://www.videohelp.com/~gfd/
Create your own movie titles/credits, transitions & effects in Linux.
By Mountain Man in forum LinuxReplies: 4Last Post: 17th Nov 2009, 16:12 -
Final Cut Express 4 can I create chapters for a DVD I create
By Jabroni4872 in forum MacReplies: 1Last Post: 18th May 2008, 11:36 -
Fade in Fade Out CD Music Software
By mn072065 in forum ComputerReplies: 0Last Post: 6th May 2008, 08:23 -
Need to create video DVD with menu & chapters from VOBs. Any suggestion
By mr_tinka in forum Authoring (DVD)Replies: 2Last Post: 4th Feb 2008, 16:26 -
What software to create a multi-title menu?
By ChrisPappas in forum Authoring (DVD)Replies: 1Last Post: 26th Nov 2007, 02:28
