Im trying to burn a pile of small mp4 clips to dvd, all are less than 5 mins long and about 5 mins in length. The quality is fairly poor at 20 fps and when added to any dvd authoring software, it inflates the filesize to about 250 mb. Any help would be greatly appreciated.
Results 1 to 9 of 9
filesize = bitrate x time. so choose a lower bitrate.
p.s. welcome to the forum--
The original nitrate is about 256, I set that as well but still does the same.
Are you trying to convert to DVD (mpeg-2) ? What program are you using ?
I've tried with sonys vegas add on dvd authoring thing. I found somewhere in the settings and changed nitrate from 2000 to 512 but nothing changed. I tried some no name freebie dvd prog that had no settings. All I chose output to dvd. I've done alot of video converting and burning years ago and never had an issue piling a bunch of mini clips to one dvd.
I don't really know what you have in mind. Mpeg-2 for DVD is in the range of 2500 - 9000 kbps (approx).
When you use an all-in-one (mpeg-2 encoding and authoring, possibly burning) tool,
you add you clips and the program will try to maximize the bitrate to give the best quality.
The bitrate calculated has to do with the running time of the clips (minutes and seconds)
not their size in MB.
Why would you want to skimp on the bitrate? Once the disk is written, it's finalized.
Not as if you can add anything to it. -
Id like to squeeze 6 hours of video on one dvd, like slp mode got vhs. Since the original video is crappy anyway, no need for a higher nitrate. Can't make a bad video look better by increasing bitrate. The way its going now, maybe get 45 mins to an hour
Then something isn't working right, Try an all in one program like AVStoDVD.
Open it up and set your preferences. (PAL or NTSC being the most important)
Add all your source files to the project. The program will determine a bitrate so that all the files
fit on the disk . Give it a try.
https://www.videohelp.com/download/AVStoDVD_234_Install.exe
What is a Reasonable Size for a DVD File Converted to AVI or MP4?
By Novice20 in forum Video ConversionReplies: 3Last Post: 23rd Oct 2011, 22:58 -
Video size for MP4 - Widescreen
By NoBuddy in forum Video ConversionReplies: 11Last Post: 12th Aug 2011, 22:13 -
Need help with mp4 video size for iphone
By skorpinok in forum Video ConversionReplies: 1Last Post: 10th Jul 2011, 12:00 -
avidemux newbie: mp4 in; avi out has no video; mp4 out has washed out video
By nonexistent_entity in forum Video ConversionReplies: 1Last Post: 22nd May 2010, 15:46 -
Keeping size in video converted from AVI to MP4
By Chocky in forum ffmpegX general discussionReplies: 5Last Post: 12th Dec 2008, 14:42
