Hi folks.
I've been living in a cave for the past few years, so I haven't been able to keep up with wich software to use when ripping and converting dvd9 to dvd5. Last time I did this, I used something called "Dvd Decrypter", Dvd Remake Pro, and Dvd Shrink.
I have read a lot of post in this forum and so far I've installed: DvdFab HD Decrypter for the ripping process, but I can't really find something to replace both Remake and Shrink since they both seem a bit outdated. I used Remake to cut out commercials and extras and such. Shrink to transcode.
Can someone please give me some advice on which programs are the best now a days. Would be much appreciated![]()
DVDShrink still works perfectly once you have ripped with DVDFabDecrypter.
What makes you thing DVDRemake will not work after ripping with DVDFabDecrypter like DVDShrink works after ripping with DVDFabDecrypter?
Yep, i use dvdfab to rip & still use dvdshrink & dvdrebuilder, depending on how much compressing needs to be done or how important it is to me.
And dvdremake & vobblanker depnding on what i want to remove. -
hech54:
I have no doubt DVDRemake will work just fine, but I was just wondering if new software has come out since the last time I was doing this stuffWhat makes you thing DVDRemake will not work after ripping with DVDFabDecrypter like DVDShrink works after ripping with DVDFabDecrypter?
Silly to pay for a license for a 3 year old program if new/better sw has come out since then
I know: If it ain't broken, don't fix it
Can DVDRebuilder do the same as Remake? -
How to disable Microsoft Update, not Windows Update?
By ukb007 in forum ComputerReplies: 17Last Post: 8th May 2011, 16:52 -
How to Update Your Duplicator's BIOS. you need to update
By krrish in forum DVD & Blu-ray RecordersReplies: 1Last Post: 29th Apr 2011, 13:02 -
Ipod update..
By SE14man in forum Newbie / General discussionsReplies: 24Last Post: 3rd Oct 2007, 17:52 -
Windows Update?
By videobread in forum ComputerReplies: 1Last Post: 12th Jul 2007, 13:27 -
Cannot Update my SVCD2DVD!!
By rodawg71 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 19th Jun 2007, 02:50
