Results 1 to 11 of 11
    Apr 2011
    I'm looking for a video player that can play standard video formats for a business application. In the video players I've tried, speeding up the video simply skips ahead in the video a few seconds depending on how fast you're playing it. I want to be able to see all the frames of the video playing faster, rather than skipping and missing certain frames. Is that even possible?
    Thanks in advance.
    Rusty Wilson
    Washington, DC
    You can use VLC Media Player, Playback->Faster or Media Player Classic (or MPCHC), Play->Increase rate.
  3. But that will only work up to some frame rate depending on the speed of your computer, codec used, frame size, etc. At some point the decoding (or I/O) of frames becomes a bottleneck.
    Apr 2011
    Thanks for the responses. Are there certain specifications, codecs, frame rates, that I can require to get an image every second, even at 8x speed?
  5. Originally Posted by Malachaidc View Post
    yes ; this is what jagabo was explaining
    e.g. if you have a 24fps video, 8x speed would be 8x24 = 192fps
    but if you had a 10fps video, 8x speed would only equate to 80fps , I'm sure you get the idea....
    If you had a 1920x1080p24 video, you probably won't drop any frames, but trying to play all 192fps, you will drop frames (CPU hardware probably not fast enough)
    If you had a SD sized video , you probably wouldn't drop any frames, because there is less data to decode per frame
    Compression differences too; most h264 profiles are more CPU intensive, than say, MPEG2 . You will max out CPU usage and drop frames more likely using stronger compressed material. (more CPU cycles required to DEcode the video)
    But if you used uncompressed video, you start running into I/O bottlenecks with single HDD's as you exceed the I/O transfer rates. For example 8bit 1920x1080p24 4:2:0 is about 95MB/s
  6. And keep in mind that no matter how much you speed up the video you will only see 60 different frames per second on a 60 Hz monitor.
    Dec 2010
    quebec
    There's a lot of forum links that points to this page !??
    are they dead links ?
  8. I have a program called cucusoft that takes dvd and copies my dvds onto my computer but some new dvds I've bought say that can't download certain movies because they have macrovision. How do I fix this problem?
  9. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Thanks in advance.
    Rusty Wilson
    Washington, DC
    We might be able to help more if you gave detail on codec and resolution.
    If you have control of both sides of the stream there are options.
    http://www.kiva.org/about
  10. Originally Posted by oki4life View Post
    Your post is completely outside the subject of this thread. Open your own thread to ask your question.
  11. Originally Posted by poisondeathray View Post
    This is a great explanation. Thank you!!
    __________________________________
    World 3d Film Exposition
