Results 1 to 9 of 9
  1. Frank-0-Video Frank-0-Video's Avatar
    Jan 2009
    Alabama - United States
    Greetings ....
    Issue Began ... Monday 4/11/2011 around 3:00 PM ET (USA)
    Description .... Whenever using any of three web-browsers (Firefox, Opera, MS-IE) on my laptop, AVAST alerts me of a threat regardless of what I click onto. In each case, AVAST identifies the running process as the specific browser in use.
    A quick scan with AVAST was done, which singled out some html and htm files. I deleted those because I had backups. However, the AVAST alerts continue with web-browsing.
    There have been no AVAST alerts when using non web-browsing apps.
    A search of this issue on the internet indicates that I may have picked up something which triggers false alerts to AVAST. If this is so, and if AVAST can't find it, what is a good solution?
    Thanx-A-Lot, Frank-0-Video
  2. Texan V Bot's Avatar
    Feb 2006
    Not sure if this will help, but have you ran a Malware scan, etc? Spybot S&D...?
    It Started In Texas
  3. Frank-0-Video Frank-0-Video's Avatar
    Jan 2009
    Greetings ...
    Running MalwareBytes (Free Version) now -- no results yet.
    Thanx
    THE Ultimate TV Tuner Device - Picks up every broadcast-cable-satellite transmission since 1928!
  4. Banned
    Nov 2005
    i'm wondering if your hosts file has been compromised...
  5. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    Try updating your Avast definitions. My sister's laptop started doing that this afternoon - any attempt to use Firefox or IE to browse a page, and Avast would complain and block it. Scans (including MalwareBytes) came up clean, no suspicious processes, startup entries or rootkit behavior. I updated Avast's definitions, and suddenly, everything was back to normal.
  6. Member classfour's Avatar
    The Heartland, United States
    Have you tried a boot scan with Avast? If updating the definitions doesn't work.....
    ;/ l ,[____], Its a Jeep thing,
    l---L---o||||||o- you wouldn't understand.
    (.)_) (.)_)-----)_) "Only In A Jeep"
    Aug 2002
    South Florida
    Go to: http://www.virustotal.com/ and see what other virus programs do. I found some false positives from Avira and checked them out there.
  8. Same thing happened to me this morning. It must've been a corrupt Avast update (I have it set to automatic). It just re-updated again for me & I can access webpages again without pop-up warnings.
  9. Frank-0-Video Frank-0-Video's Avatar
    Jan 2009
    Greetings ....
    Turned out to be a bad definitions update by Avast. They issued corrections within the hour, and now everything's running OK again.
