    Nov 2010
    india
    my mobile is playing some mkv video files without no problem but for some mkv files its fail to play audio .... is there is any application to convert mkv to mkv to get that audio back ?
    You could try reconvert the audio to ac3 with PopCorn MKV AudioConverter.
    Or else PLEASE give more info. What is the audio in the mkv that does not work? What is your mobile?
    Nov 2010
    india
    thanks for your help bro ........this is the audio information of that mkv file . mobile is nokia N-8
    Audio
    Format                           : MPEG Audio
    Format version                   : Version 1
    Format profile                   : Layer 3
    Mode                             : Joint stereo
    Mode extension                   : MS Stereo
    Codec ID                         : A_MPEG/L3
    Codec ID/Hint                    : MP3
    Duration                         : 3mn 33s
    Bit rate mode                    : Variable
    Bit rate                         : 185 Kbps
    Minimum bit rate                 : 32.0 Kbps
    Channel(s)                       : 2 channels
    Sampling rate                    : 44.1 KHz
    Compression mode                 : Lossy
    Delay relative to video          : 100ms
    Stream size                      : 4.72 MiB (4%)
    Writing library                  : LAME3.97
    Encoding settings                : -m j -V 2 -q 3 -lowpass 18.6 --vbr-new -b 32
    by the way while converting that mkv file via "PopCorn MKV AudioConverter." will it make any damage to video quality ?
    And the ones that works?
    Standard mp3 should work fine I guess.
    Nov 2010
    india
    the converter says "Skipping conversion - none of the audio tracks can be converted or the conversion has been disabled:
    Audio Track #1 of codec A_MPEG/L3 is not of a codec type that can be converted by AudioConverter"
    is there is any codec for this ?
  6. I'm a MEGA Super Moderator Baldrick's Avatar
    Try another converter like freemake video converter, xmedia recode. They have profiles for many mobiles.
