Hi,
I managed to convert an unprotected MPEG2 DVD (720x405) (1.2 GB) to a MKV 720x400 (200 MB) using Handbrake.
Now I need to convert the MKV to SWF, to host the SWF in intranet portal.
I tried some shareware/trialware and I set parameters as 720x400 for SWF. But after conversion, I opened the SWF in IE/Firefox the video plays in a small area and not in 720x400 resolution as configured. The converted SWF says the resolution is 720x400 but when played in a browser the video is played in a small area and not in 720x400.
Please suggest me some freeware/open-source tools that can compress the video to a decent size SWF and maintain the resolution of the converted file while played in IE/Firefox ?
Thanks and Regards
Rafales
Thanks for the reply.
I used Xilisoft and Joboshare tools to convert MKV to SWF. the converted SWF when played in the browser, the display resolution was shrinked to a small box rather than the 720x400.
I can't convert to MP4 or other formats. Since the requirement is to convert to SWF, which can be played in any browser. -
Try freemake video converter. It can output swf.
BUT swf=flash and so is mp4 with a flash player...even though it wont work with older flash. -
If you are using the <object> tag in html, you can set the size parameters for width and height...
<div class="content-pagetitle">
<object classid=
"clsid
27CDB6E-AE6D-11cf-96B8-444553540000" codebase=
"http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=6,0,0,0"
width="310" height="167" id="your_filename.swf" align="">
<param name="movie" value="your_filename.swf" />
<param name="quality" value="high" />
<param name="bgcolor" value="#333399" />
<embed src="your_filename.swf" quality="high" bgcolor="#333399"
width="310" height="167" name="stihl.swf" align="" type=
"application/x-shockwave-flash" pluginspage=
"http://www.macromedia.com/go/getflashplayer" />
</object>It's not important the problem be solved, only that the blame for the mistake is assigned correctly
free tool to convert m2ts to mkv ?
By tagada45 in forum Video ConversionReplies: 7Last Post: 17th Feb 2014, 07:28 -
If MultiAVCHD is not supported, what is good tool to convert MKV to Bluray?
By Yanta in forum Newbie / General discussionsReplies: 7Last Post: 16th Sep 2011, 02:38 -
Tool to convert SWF (actionscript) to uncompressed AVI or image sequence?
By Koppel in forum Video ConversionReplies: 5Last Post: 1st Jul 2011, 14:23 -
Problem merging video clips and suggestion on best tool?
By nerys in forum EditingReplies: 1Last Post: 18th May 2011, 01:41 -
Is there any paid tool for swf conversion?
By marora26 in forum ffmpegX general discussionReplies: 1Last Post: 10th Aug 2009, 10:32
