More info than you need: I went to the public library catalog looking for an artist I like. I found Best Of, The Collection, Complete Hit Singles and Celebrate (2CDs). All of the songs that I like are on all four collections, and I own Celebrate. Now the problem: I am trying to make a single CD that contains the songs I like from the two CD set. I am trying to get the text to correctly identify the songs. I have tried both Nero and Media Monkey. Both make usable CDs, but the Media Monkey text identifies track one with the track two title, track two with the track three title, and so on. Every song is identified with the name of the song after it. The Nero CD was even more random. What can I use to create an audio CD from other commercial CDs that will correctly identify the tracks in the text?
This is MUCH MUCH easier than you think.
1) Rip the CDs with something like Exact Audio Copy. Rip to uncompressed format. There are guides to using Exact Audio Copy on the internet if you can't figure it out.
2) Use Nero Burning ROM. Do NOT use Nero Quick Start. If you do not use Nero Burning ROM then you have no hope of getting this right. Start Nero Burning ROM, choose Audio CD, and drag and drop the tracks from your rips in whatever order you like. After the tracks are added, double click on the tracks one at a time and change the name of the tracks and the artist to whatever it is. Make sure that the option to do a multisession burn is NOT checked. Burn as "disc at once" and NOT as "track at once" if given a choice. Burn the disc. It will have the CD text information available to anything that supports it on playback.
Other rippers may or may not have the correct information when ripping. If you want to use another ripper that might be able to rip to individual track names and then use those with Nero so you don't have to set them manually, that is fine, but my method will work. You just have to do it manually.
Monitor Is Making my Text Blurry
By imdaman in forum ComputerReplies: 43Last Post: 2nd Sep 2014, 13:25 -
Read text create audio and convert text to synced subtitles in mp4
By Philip Lean in forum SubtitleReplies: 1Last Post: 25th Feb 2010, 08:54 -
ISO: frame accurate *multiple audio* mpeg2 editor
By febefe in forum EditingReplies: 1Last Post: 5th Sep 2009, 18:05 -
Audio Extraction from dvd's... best, effective and accurate method?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 25th Mar 2009, 13:34 -
Putting text over a video (making a compilation RATM DVD)
By Salva Veritate in forum EditingReplies: 4Last Post: 1st Sep 2007, 13:52
