When I bring an AVCHD video clip into VirtualDub from my Lumix GH1, VirtualDub only "sees" half of the movie. That is, if you run the scroll bar at the bottom of the screen all the way to the right, you only see the first half of the movie. Any VirtualDub operations that you attempt also end halfway through the clip.
I tried to use MediaCoder to reformat the original movie so that VideoDub would be happier with it, but now VideoDub will not open the resulting MP4 at all (NewMovieFromFile error). I know nothing about Containers, Codecs and the like, so I probably selected a brain-dead output format while running MediaCoder. Perhaps one of you can suggest the proper MediaCoder settings.
You can see my original AVCHD movie (30 MB) at http:\\www.jonbondy.com\P1010101.MOV
You can see the output from MediaCoder (1 MB) at http:\\www.jonbondy.com\P1010101.mp4
Any thoughts about how to get the AVCHD movie into VideoDub so I can work on it? I'm trying to convert movies so that they appear to be time lapse, by removing frames (decimation).
With VD, that's usually caused by a break in the video. Software players can often skip over this, but video editors are more sensitive.
But someone here with more experience with this may have a better explanation and some ideas. -
The QuickTime input plugin used to open .mov/.mp4 files in VirtualDub have this problem with some files, but look at the reply here => http://forums.virtualdub.org/index.php?act=ST&f=4&t=19938
Codec Toolbox RS (A tool to read/change merit of codecs and many other things) -
ale5000: in my experience, the QuickTime plugin that is used to open MOV files in VirtualDub has this problem with LOTS of files. Strangely, if you open the video and play it with the QuickTime player, it plays just fine.
@jon_bondy
Depending on selected video decoder mode. Usually ICM Decomp works well for AVC video and MoviesTask for other.
However Decomp Sequence mode usually does not work too well - I do not understand why this is default mode (QTInput for Avisynth (created by same author) uses MoviesTask as default). Looks like a mistake...?
BTW
I see full sequence in this video.
Also it's just MJPEG video and PCM audio - can change container to AVI, with no significant problems.VideoAudio.pl - Serwis o technologii wideo & audio
AVCHD from panasonic lumix, which software is compatible?
By rocketman778 in forum EditingReplies: 0Last Post: 25th Nov 2011, 15:53 -
Lumix DMC-TZ10 mts file looks slightly washed out converting AVCHD to mp4
By nhague in forum Video ConversionReplies: 2Last Post: 10th Jul 2010, 22:47 -
Virtualdub for AVCHD?
By cheerful in forum Newbie / General discussionsReplies: 1Last Post: 21st Oct 2009, 20:14 -
Matte box options for the GH1
By kippard in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 2nd Oct 2009, 03:20 -
Panasonic GH1 consideration
By kippard in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 45Last Post: 30th Sep 2009, 16:13
