question: home theater says non-supported resolution for some avi files and i cannot understand why!
i have the following:
1. file:
blabla.720p.BDRip.XviD.AC3-blabla.avi
mediainfo details
2. tv: (european union specs)
sony bravia kdl-32s2530 32”
screen resolution: 1366 horizontal * 768 vertical
video color system:
analog: pal, secam, ntsc 3.58, 4.43 (only video in)
digital: mpeg-2 mp@ml
hdmi in supports:
- video: 480i, 480p, 576i, 576p, 720p, 1080i
3. home cinema: (european union specs)Philips hts3115
disc section:
laser type: semiconductor
disc diameter: 12cm / 8cm
video decoding: mpeg-1 / mpeg-2 / DivX 3/4/5/6, Ultra
video dac: 12 bits
signal system: pal / ntsc
video format: 4:3 / 16:9
video s/n: 65db
composite video
output: 1.0 vp-p, 75Ω
audio dac: 24 bits / 192 kHz
frequency response : 4hz–20khz (44.1khz), 4hz– 2khz (48khz), 4hz-44khz (96khz)
supports fat 16 κ 32, not ntfs
plays: DivX files on CD-R[W]/DVD+R[W]
-DivX 3/4/5/6, DivX Ultra
-qpel (quarter pixel)
points to note and problem:
the avi resolution from media info is 1280x720 and the tv screen resolution is 1366x768, so there should be no problem there.
so, it is definitely then a home cinema issue. i have connected the home theater with the tv via hdmi and have selected 720p at home theater hdmi setup. still no go! why?
Your dvd/divx player does not support HD resolutions. Most divx players just supports up to around 720x576.
Yep, a PC would be the best. A 10 meter VGA works good or a 10 meter high quality HDMI/DVI cable. You need also a audio cable if you use VGA or DVI.
the hdmi solution is preferable to vga then? the tv does not have a dvi input.
also since i'm going to rebuild one of my pcs, should i look out for some specific graphics card in light of this situation?
and for audio do i use that dual cable with white and red jacks for left and right?
below is the pc signal reference chart and all tv sockets for external equipment:
A simple solution is to use a media player like the Western Digital WDTV Live Plus. Or any of a number of others: Seagate FreeAgent Theater+, Asus O!Play, Diamond Media Wonder, TVIX, Patriot Box, AC Ryan Playon, Hauppauge HD Media Player, Xtreamer Pro, Dune HD, Popcorn Hour, Boxee Box, PopBox...
http://www.iboum.com/net-media-players.php -
InterVideo Home Theater
By aadis in forum Capturing and VCRReplies: 8Last Post: 4th Feb 2011, 03:55 -
Home Theater
By Al27 in forum Newbie / General discussionsReplies: 1Last Post: 15th Jan 2011, 18:37 -
Home Theater Projectors
By Lucifers_Ghost in forum Off topicReplies: 17Last Post: 18th Sep 2008, 02:36 -
Is there a list of supported resolutions for DivX certified DVD players?
By quitearush in forum DVD & Blu-ray PlayersReplies: 2Last Post: 12th Jan 2008, 06:26 -
all in one home theater systems
By CODEWERKX in forum Newbie / General discussionsReplies: 1Last Post: 4th Dec 2007, 12:09
so that's why!!!
