Results 1 to 9 of 9
  1. Member SE14man's Avatar
    Jul 2005
    Queensland
    Have just upgraded my RAM on my desktop another 2 GB. It was already 2 GB so i added another 2 GB stick in there.
    Was a bit concerned to see that on the computer properties only 3.25 GB of it was usable.
    Whats the reaosn for this?
    Thanks guys.Click image for larger version
  2. Member rhegedus's Avatar
    on the jazz
    32 bit OS limited to 4GB RAM
    Regards,
    Rob
    Feb 2008
    Twin Peaks
    Agreed that the reason for your issue is that a 32 bit operating system can only handle up to 3.5GBs of RAM, if you intend to use more than that you'll need a 64 bit operating system. Before you may choose to do that you'd need to also make sure that your processor is 64 bit compatible, which I believe it is.
  4. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    http://www.kiva.org/about
  5. Member edDV's Avatar
    Mar 2004
    Originally Posted by lowellriggsiam View Post
    Agreed that the reason for your issue is that a 32bit operating system cad handle up to 3.5GBs of RAM, if you intend to use more than that you'll need a 64 bit operating system. Before you may choose to do that you'd need to also make sure that your processor is 64 bit compatible, which I believe it is.
    Processor probably is. Drivers and apps maybe not.
  6. Member SE14man's Avatar
    Jul 2005
    Queensland
    Hi fellas,
    Thats fantastic!
    Gr8 answers!
    Thank u very much
  7. Member SE14man's Avatar
    Jul 2005
    Queensland
    Wouldi need a certain graphics card for 64bit or wouldi just need to buy a 64 bit edition of either windows xp or windows 7 and that would be it?
    How can you tell if a computer will work with 64Bit, is it how fast it is in ghz?
    Thanks guys
  8. Banned
    Freedonia
    Thanks guys
    You don't need a special graphics card. You just need a 64 bit version of Windows.
    You have to look up your CPU to see what it's capable of. In your case your processor can do 64 bits. Honestly, I don't know if Intel and AMD even make 32 bit only processors any more. If they make them at all, I would guess that they are only for laptops.
  9. Member SE14man's Avatar
    Jul 2005
    Queensland
    Fantastic,
    Thanks for your helpful info.
