I have some avi files that are out of sync. I believe it's because i captured them from the web using the wrong FPS. Anyway, i tried YAAI and i was wondering if there are any others out there, as i'm having trouble with YAAI. Hopefully the sync software is freeware.
Thanks!
Why don't you just recapture them using the correct FPS? Believe me, you won't regret the extra time vs trying to sync up the files.
ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
Good software to add/ sync audio tracks?
By jiopi in forum EditingReplies: 2Last Post: 14th Feb 2011, 07:25 -
What's the best software to sync subtitles to video VisualSubSync,Aegisub??
By LegendaryGamer in forum SubtitleReplies: 1Last Post: 5th Mar 2010, 13:44 -
Software to make sure the audio and video of a authored dvd are in sync?
By snafubaby in forum Authoring (DVD)Replies: 7Last Post: 1st Oct 2007, 07:13 -
looking for software that will analyse lip movement to sync audio/video
By jimdagys in forum Video ConversionReplies: 3Last Post: 8th Jun 2007, 08:05
