Just started looking for ripping software. Many reviews are from 2008. Wondering what are the choices today.
1. decryption
2. title/menu selection (remove warning, commercial, etc)
3. compression control
Any recommendation?
Thanks!
Results 1 to 9 of 9
The reason I asked was because there is a third choice for decryption if you want to make .mkv files from your dvds. That program is called MakeMKV and it can decrypt both blu ray and commercially made dvds. Output from dvds is always an .mkv file encoded to h264 (as far as I am aware), but it does also seem to allow full backups of blu ray to the hard drive, minus only the encryption. MakeMKV is free to use for dvds and while it is in beta, is free to use for blu ray. You can get new beta keys for the program at their forum.
MakeMKV will let allow you to select the sections of the movie you wish to keep, so you can remove foreign language tracks, extraneous subtitles, etc.Last edited by Kerry56; 9th Apr 2011 at 22:09.
an alternative to makemkv is to rip with dvdfab or anydvd and then use ripbot264. It has a mkv output an mp4 as well. Plus divx hd and avchd in the newest format. (but as far as i know ripbot264 doesn't work off an optical disc, it needs to be on the harddrive - but its usually best to convert off a harddrive for much faster access and to save wear and tear on your optical disc drive).
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
DVDFab is my choice - I finally bought the full version - the updates for the free one are behind, so ripping a late release can be problematic.
;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep"
Help needed with HD camcorder, PC and editing software choice
By Paul Tyrrell in forum Newbie / General discussionsReplies: 5Last Post: 13th Nov 2008, 15:02 -
dvd ripping software - help!
By counterstrikedude in forum DVD RippingReplies: 8Last Post: 27th Oct 2008, 00:17 -
Best DVD ripping software
By AllanWoody in forum DVD RippingReplies: 17Last Post: 14th Aug 2008, 14:32 -
Any HD DVD ripping software out there for Mac?
By vivsavage in forum MacReplies: 1Last Post: 9th Jan 2008, 09:46 -
What is your choice for a DVD Player software??
By videobruce in forum Software PlayingReplies: 10Last Post: 31st Dec 2007, 07:56
