Hello savvys, does avchd to mpeg2 look better than just recording in mpeg-2 in the first place with a camcorder?
what do you mean?
SD MPEG2 for DVD ? at DVD bitrates
or HD MPEG2 ? at high bitrates ? for blu-ray ?
or something else ? -
I guess I mean SD MPEG2 for DVD at DVD bitrates. I'm not sure. I have this Sony camcorder that redords in either AVCHD or Mpeg-2, and I know HD is higher bitrate but I'd like to make a regular DVD of the stuff I've filmed. The question is, let's say I record in avchd and then import the files in, for instance, Sony Vegas and then render as mpeg-2, will that look better than if I record in Mpeg-2 in the first place?
It will depend on a many factors.
I would guess it will probably look worse recording to SD MPEG2 directly, because it is a 1 pass (probably CBR) realtime hardware encoder . Offline software encoders will produce higher quality and allow for multipasses
To be sure, you would have to do some short tests
Converting AVCHD(MTS) to MPEG2(DVD)
By manyoo in forum Newbie / General discussionsReplies: 5Last Post: 4th Aug 2011, 02:10 -
Why would anyone want to convert MPEG2 to AVCHD???
By Alphamale1956 in forum Video ConversionReplies: 11Last Post: 9th May 2010, 06:41 -
Viewing mpeg2/AVCHD directly from a SD card on a TV
By Ravis in forum Newbie / General discussionsReplies: 5Last Post: 6th May 2010, 13:53 -
Time Lapse help, mpeg2 from AVCHD
By cjbrown80 in forum Newbie / General discussionsReplies: 2Last Post: 28th Jun 2008, 08:26
