Hey, it's been a year or two since i last looked into recording gameplay from my 360 and at the time i had my eye set on the hauppage pvr but i have since changed my setup so i need some advice. My current Setup is as follows
(Video) Xbox > VGA > Monitor
(Audio) Xbox > audio jacks > piggy back type connectors > steel series live mix > headset
My monitor has only D-Sub(VGA), DVI, and HDMI. DVI slot is taken by pc. I am looking for the cheapest way to record gameplay onto my pc from my xbox. I wish to play in max res on my monitor at the same time with no induced lag. There are a number of options i have considered all of which i can live with, could somebody please help me to find a solution for each scenario and a rough price, GBP pleaseI would prefer the cheapest possible solution as i am on a pretty tight budget atm. Any advice you can give me will be greatly appreciated.
1. Play in HD, record in HD at same time
2. Record in HD, not play at same time
3. Play in HD, record in SD
4. REcord in SD, not play at same time
ROXIO GAME CAPTURE for you.
You play in your TV HD (NO LAG) and Recording in PC, SD (480p@60fps).
Take a look here: RGC REVIEW
Xbox 360 Capture question
By unp0ssible in forum Capturing and VCRReplies: 2Last Post: 19th Sep 2011, 21:41 -
capture cards 360
By ihazcheezburga in forum Capturing and VCRReplies: 2Last Post: 19th Feb 2011, 20:14 -
Looking to capture 360 gameplay
By Noxous in forum Capturing and VCRReplies: 5Last Post: 11th Jan 2010, 11:12 -
Capture card for 360.. Capture in SD play on TV in HD?
By fazeshot in forum Video Streaming DownloadingReplies: 4Last Post: 12th Nov 2009, 17:04 -
Trying to capture Xbox 360 footage - Excellent Quality capture?
By Mysteriouskk in forum Capturing and VCRReplies: 5Last Post: 11th Jun 2007, 20:42
