I have had svcd2dvd for years and used it to convery mostly avi's to dvd with no issues. The average time for a conversion would be roughly a couple of hours give or take. I use windows XP btw.
Recently the conversion time has risenm to upwards of 8 hours for the same size of avi for no obvious reason??? I downloaded and installed the 2009 version and it is no better re speed of converting? Can anyone suggest what might be causing this?
Also how do I direct the converted files to be burned by nero in the settings please??
Thanks![]()
ram has a nasty habit of failing
try various testing aps
also, try adaware and clean the machine upLast edited by zoobie; 9th Apr 2011 at 11:48.
AutoGK suddenly not reliable
By marioval in forum Video ConversionReplies: 2Last Post: 11th Oct 2010, 17:38 -
CamStudio suddenly closes
By terrypin in forum Newbie / General discussionsReplies: 1Last Post: 21st Feb 2010, 08:40 -
PC suddenly forces me to shut down
By Jeikobu in forum ComputerReplies: 15Last Post: 3rd Dec 2008, 19:18 -
Some Cable channels suddenly won't come in
By chimneysweep in forum DVB / IPTVReplies: 21Last Post: 6th Feb 2008, 13:26 -
Dvd drive burning very slowwww
By Soixante in forum DVD & Blu-ray WritersReplies: 13Last Post: 24th Dec 2007, 06:55
