ok guys,
Got 2 laptops, both same proc/memory spec. Both Vista prof 32bit same service pack. Same players, VLC & WMP versions. Settings on players the same. The mpeg-4 file plays perfect on one, the other one freezes every few frames etc. driving me mad. What can I try? The media info is here:
General
Complete name : \VID00030.MP4
Format : MPEG-4
Format profile : Sony PSP
Codec ID : MSNV
File size : 102 MiB
Duration : 1mn 34s
Overall bit rate : 9 103 Kbps
Encoded date : UTC 2010-01-05 18:24:48
Tagged date : UTC 2010-01-05 18:24:48
Video
Format : AVC
Format profile : Main@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 1 frame
Format settings, GOP : M=1, N=10
Codec ID : avc1
Duration : 1mn 34s
Bit rate mode : Variable
Bit rate : 8 967 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 30.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.324
Stream size : 101 MiB (99%)
Language : Japanese
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 1mn 34s
Bit rate mode : Constant
Bit rate : 132.3 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Compression mode : Lossy
Stream size : 1.47 MiB (1%)
Language : Japanese
Open the task manager in each and see if anything else is using up the CPU.
Burned DVD Plays On Laptop, LG Player; Does Not Play On Panasonic Player
By Valentin in forum Authoring (DVD)Replies: 15Last Post: 18th Jul 2010, 13:55 -
Formatting laptop, how do i know if a laptop has wifi capabilities?
By ricardouk in forum ComputerReplies: 8Last Post: 21st Nov 2008, 10:24 -
DVDs work in desktop PC but not in laptop - previously worked in laptop
By Brent Jewell in forum Newbie / General discussionsReplies: 3Last Post: 6th Nov 2008, 20:40 -
using second laptop as a video in from laptop with broken display
By joycefitz in forum Newbie / General discussionsReplies: 4Last Post: 19th May 2008, 00:56 -
Copied dvd's stutter, pixelize, & freeze up. Why now?
By Sal C in forum DVD RippingReplies: 5Last Post: 31st Mar 2008, 16:48
