Results 1 to 10 of 10
    Apr 2011
    Turkey
    When i tried to rip any video, [No Audio] written in the audio section. Also, i started ripping that takes 1 sec. and nothing happened.
    I'm sorry for the bad English
    Screen Shoot:
    What is your source? A blu-ray you ripped or mkv or something else?
    Apr 2011
    Turkey
    sometimes mkv sometimes avi or mp4 but i get same error.
    This is not any blu-ray conversion/ripping then. Moving you our video conversion section.
    Does the audio work if you play the source video in windows media player? Maybe reinstall ffdshow.
    Or use handbrake.
  5. Check if cmd.exe is working (it can be disabled in registry). Few weeks ago some virus/trojan blocked cmd.exe in my system
    and ripbot264 could not demux or encode anything.
    Apr 2011
    Turkey
    İ did it but problem is continuing.
    cmd.exe is working
  7. edit ripbot264.ini and change temp folder location
    Apr 2011
    Turkey
    ripbot264.ini :
    [settings]
    // TEMP=uses System temp ; AUTO = selects the biggest partition ; C , D ... uses specific partition
    StoreTempFilesin=AUTO
    KeepJobsQueue=1
    DefaultProfile=[HIGH 4.0] HD . BluRay . Consoles
    DefaultEncodingMode=CQ
    DefaultModeValue=22
    //Directory must exists!!! D:\movies\ is correct but D:\movies is incorrect!
    DefaultOutputPath=desktop
    // allowed values are mp4 , mkv , bluray , mkv-divxhd
    DefaultContainer=mp4
    // in GiB (1GiB=1024 MiB) , 0 = no splitting
    SplitM2TS=0
    FastFirstPassin2passMode=1
    //AnyDVD DVD/HD-DVD/Blu-Ray decryptor will be automatically activated with RipBot264
    ExecuteAnyDVD=0
    x264LowPriority=1
    // it will use 64bit version of x264 on 64bit Windows. up to 10% faster encoding speed.
    Usex264x64=1
    So how can I do it?
  9. replace "auto" by another available partition.
    example
    StoreTempFilesin=D
    Apr 2011
    Turkey
    i did it nothing change
