Hi,
I have an .mkv videofile where the audiostream is far off from what the video shows. Probably over 10 seconds...
Is there any easy software which can correct this? Natively would be nice (stay in .mkv format) but it's also possible to demux the file with tsMuxeR.
Video is h.264, High@3.1 1280x528p, 24fps, Audio is .ac3, 448kbps, 48khz, stereo.
Tia,
Highend
AnonymousGuest
AnonymousGuest
avidemux isn't working properly on my system (hanging on video playback, stuttering audio, unable to do simple video editing without loosing audio sync). Portable, latest version, Win 7 Ultimate x64. I'm currently trying to get used to mkvtoolnix which is able to remux streams from tsmuxer with editable audio sync times. Thanks for your suggestion.
Highend -
Your system isn't fast enough for what I suspect to be hd mkv file the solution that often works for people is to change the view to zoom 1:2 (halfsize) which makes it use less resources.
win7 64bit doesn't mean your computer would process better it depends if yours is a single, dual , quad core processor.
Video out of sync after audio track substitution (MKV)
By ConverterCrazy in forum EditingReplies: 15Last Post: 1st Apr 2012, 09:22 -
how to correct out of sync video/audio in mkv file
By 55trucker in forum Video ConversionReplies: 37Last Post: 22nd Mar 2011, 12:08 -
Audio and Video out of sync when converting MKV's w/ GOTsent
By Peter25 in forum Newbie / General discussionsReplies: 3Last Post: 12th Apr 2009, 23:45 -
MKV Muxing Audio Out-of-Sync with Video
By Cube11 in forum Newbie / General discussionsReplies: 0Last Post: 26th Jun 2008, 14:27
