After I encod something or multiplex it I get a buffer over/under flow and it sayz that playback may not work!
How do I correct this?
EXZILERATE
http://forum.vcdhelp.com/search.php
Hard to correct, unfortunately, probably impossible if you want to create a standard (S)VCD.
More details please. VCD / SVCD, encoder, MPEG-1 / MPEG-2, resolution, bitrate, CBR / VBR (min,max), VBVbuffer size, GOP structure, which multiplexer? If you are happy with X(S)VCD, then there might be an easy solution. -
It shouldn't be too hard to tell me your encoder settings.
If you dont like that try TMPGEnc beta12 > file > MPEG tools > VBV buffer size optimization. Note, the final MPEG will not be (S)VCD compliant.
TSMuxer Reading Buffer Overflow
By Fenrirjack in forum Video ConversionReplies: 0Last Post: 19th Dec 2011, 18:21 -
MuxMan : Buffer Underflow
By Bonie81 in forum Authoring (DVD)Replies: 3Last Post: 23rd Oct 2011, 16:38 -
ffmpeg gives buffer underflow
By zkab in forum Video ConversionReplies: 2Last Post: 9th Aug 2010, 04:45 -
Buffer overflow recording was stop
By Seasonal in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 15th Apr 2009, 17:15 -
Buffer overflow in tmpgenc?
By themaster1 in forum EditingReplies: 7Last Post: 15th Jun 2007, 17:08
