Hi, what would cause this error? I have created a blu ray folder (BDMV) that i am trying to convert to BD-9 and i keep getting this error during the process. I have downloaded the latest version. The video is NTSC 720p 59.94fps with AC3 audio. File size is 17gb.
thanks.
Can you shrink other blu-rays?
Have you installed correct required decoders? Use http://www.jdobbs.net/freeware/inspect.exe to check.
Created blu-ray folder? Ripped from a commercial blu-ray or downloaded or made yourself?
Or try shrink with AVCHDCoder or BDtoAVCHD. -
I have not tried to shrink other blu rays. These are folders i created myself.
AvsToDVD aborts during finalisation
By alhenderson in forum Authoring (DVD)Replies: 25Last Post: 15th Jan 2013, 17:53 -
Hauppauge 2250 Tuner Card Aborts Recordings
By rixware in forum Capturing and VCRReplies: 8Last Post: 30th Jul 2012, 13:14 -
BD Rebuilder failure to extract audio issue
By fnord333 in forum Blu-ray RippingReplies: 8Last Post: 26th Mar 2011, 14:37 -
BD REbuilder ERRor - Error in attempt to extract audio/subs.
By ajhansen91 in forum Blu-ray RippingReplies: 1Last Post: 26th Mar 2009, 15:39 -
Capture aborts when media format changes
By Undead Sega in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 22nd May 2008, 18:09
