Hello,
Need some help, im going made trying to find the issue. I can not play back blu-ray movies with PowerDVD. they appear like a mulitcoloured snow? I have tried many Blu-ray disks and even ISO ripped to HDD. I have AnyDVD running in the back ground.
I can play the video files with splash lite? or when i explore the files and select a file to play it works ...but when i want to play the blu-ray as a whole through PowereDVD the video is multicoloured? Audio is fine!
What could be the issue?
Im using a Laptop Sony Vaio VGN-FW43G, windows 7, intel Duo 2, 3GIG RAM, ATI HD 3470. laptop screen supports 1080 playback.
Please help so I can watch my films
Results 1 to 10 of 10
PowerDVD is terrible. You'd be better served to use Total Media Theater as suggested.
Are you running Daemon Tools? PowerDVD doesn't like Daemon Tools. -
Stupid question time. You do have a Blu-ray player in that laptop ?. I just checked the specs and all I see is a standard dvd drive.
PowerDVD is very restrictive. It prefers that you have HDMI connections between your monitor and your computer. If you do not have an HDMI connection I do not know what version 10 will do. Maybe what you see is normal for version 10. Or maybe it's normal for external BluRay drives which for some reason known only to Cyberlink (they make PowerDVD) they think that external BluRay drives are bad and they don't support them. Yes, I am really saying that it may be "normal" for PowerDVD not to work. I am serious.
I have said this before and I am not joking. Each new release of PowerDVD is more consumer unfriendly than the one before. I think PowerDVD is such a piece of crap that even though I got version 9 for free with a BluRay burner I bought, I paid $99 US for a copy of Arcsoft Total Media Theater instead. -
Many people say that each successive version of PowerDVD is less and less functional. I have PDVD8 and think it stinks compared to TME (same player essentially as in TMT3). But it does (did) work on my machines before I uninstalled it.
Dunno what else to suggest, as WinDVD is bad too. The only full-featured software Blu-Ray players that are any good are by ArcSoft, IMO.Pull! Bang! Darn!
Problems playing Blu-ray with PowerDVD 8
By electrontau in forum Software PlayingReplies: 2Last Post: 27th Jan 2011, 21:29 -
PowerDVD 10 - Blu-ray sound OK, menu navigation OK but no image
By rilopes in forum Software PlayingReplies: 4Last Post: 10th Aug 2010, 11:16 -
LITE-ON iHES 106 BD-ROM + PowerDVD 8 cannot play Blu-ray disc
By eppingwest in forum Software PlayingReplies: 2Last Post: 23rd Apr 2010, 14:51 -
Cannot play Blu-Ray in PowerDVD or WinDVD - images are multicoloured snow
By AnitaPeterson in forum Software PlayingReplies: 5Last Post: 17th May 2008, 12:51
yes I do Have a blu-ray burner^^ It's external LG Model BE12LU30
