    Apr 2011
    Melbourne, Australia
    I am staring a documentary course where we will use Final Cut Pro to edit . I want a semi professional camera that records on card that i can edit straght wit FCP avoiding any file conversions. my bucget is around $5000 to $8000 . I was looking at Sony nx5p but i believe i need to do a file conversion before i can edit which is a drag. I am a newbie so any help would be appreciated
    Not going to happen.
    Not with all those requirements.
    Apr 2011
    Smurf could you expand please on your reply. I really need some advice on whether there is a camera that i can get that needs no conversion to FCP and if so what would it be? If there isnt one then let me know.
  4. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    The JVC GY-HM100U (~$2795) transfers direct as MPeg2 *.mov or *.mp4 but that doesn't mean no recode. FCP isn't a smart encoding MPeg editor. If that is your priority, look at GVG Edius or Sony Vegas Pro.
    http://pro.jvc.com/prof/attributes/features.jsp?model_id=MDL101845
    http://pro.jvc.com/pro/attributes/HDTV/manual/editing1.html
    There are rumors of a new MPeg (MPeg2 and AVC) native FCP this April at NAB. We shall see.
    Assuming this happens, expect CPU requirements to be rather extreme. Not for Grandma's MacBook Pro.
    http://www.kiva.org/about
    Apr 2011
    Thanks edDV That helps a lot. FCP is the editor i will be using in my training over the next couple of years so i want to keep it simple for now.and it looks like its worth considering these JVC models Thanks I will check them out. Really appreciate your help
