http://cgi.ebay.com/JVC-HR-s2901U-SVHS-ET-HDMI-out-720-1080-video-/170625340304
Supposedly this machine has a custom up-converting HDMI board in it. Why would you waste your time doing that to a mid-grade VCR like this? Why not something nicer like a 7000-series at least???
I mean, if you didn't know what you were doing, and you didn't want to RUIN a nicer VCR, I guess I could see testing it out on this type of model first...
Results 1 to 12 of 12
Did you miss this?
This isn't a factory upscale VCR. It is a science fair project. Yes, one would test first with a cheaper machine. Not clear a 7000 would do much better. Depends where the A/D is done.This VCR was modified by local tv technician and works good. On the back of the VCR you have option of 720p and 1080p upconversion and it works great and you dont have to run all the cables to tv just one HDMI and red and white to stereo receiverRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Here's a project I'd like to tackle: building the Panasonic DMR-ES10 filtering circuit. That way everyone doesn't have to buy a whole friggin DVD recorder just to pass a signal through for filtering!
Too bad it used a Panasonic proprietary DIGA chip, though. The chip alone is $45 from Encompass parts. Probably not worth it... -
Very interesting this VTR i'd be interested on how he's managed to achieve such brilliant work.
*** DIGITIZING VHS / ANALOG VIDEOS SINCE 2001**** GEAR: JVC HR-S7700MS, TOSHIBA V733EF AND MORE -
He bought one of these:
http://www.amazon.com/Orei-XD-901-Multi-System-Composite-Converter/dp/B004UNYX9M
and glued it into the VCR case. It's not rocket science. -
Questions and answers about this item
No questions or answers have been posted about this item.
Ask a question
"I can wire anything directly into anything!" - Professor Farnsworth -
Check the specs from Amazon ...claims a built in TBC. (jagabo's link)
Technical Details
- Change RCA Composite or S-Video to HDMI Converter - Automatically convert signals from PAL or NTSC analog to NTSC Digital
- Support Up-Scaling Output Resolution Upto 1080p
- Specially designed to work with any Analog source like Satellite Receivers, cables boxes, Wii, PAL VCR, Camcorder, PAL Receiver and convert it to display on NTSC HD TV
- Built-in Time Base Correction (T.B.C) for signal synchronization
- World Wide Power supply. 100-240 50/60 Hz auto switching power supply for use anywhere in the world.
VCR Comparison: JVC SR-W5U vs JVC SR-V101US
By robjv1 in forum RestorationReplies: 18Last Post: 22nd Apr 2021, 04:36 -
Windows Live Movie Maker - Custom output settings?
By abw1987 in forum Newbie / General discussionsReplies: 4Last Post: 27th Aug 2010, 14:46 -
Possible to output hdmi and optical output on the ps3??
By mrswla in forum DVD & Blu-ray PlayersReplies: 10Last Post: 3rd Feb 2009, 16:17 -
hdmi and av output
By gunukhan in forum DVD & Blu-ray PlayersReplies: 11Last Post: 1st Aug 2007, 13:04 -
Will filters on my JVC SVHS model HR-S2901U work if used as pass-thru?
By theweight99 in forum RestorationReplies: 6Last Post: 7th Jun 2007, 22:21
