I changed the video output on my Toshiba DVD player from AV to HDMI.
Now I want to go back to AV but the menu does not include making video out AV. How do I do it, especially if I cannot view the scree? Can I set it back to AV from the remote?
Don't you change the input type on your TV and not your DVD player? That's the way I did it on my Toshiba.
ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
the toshiba has on the setup menu an option for setting the video output.
i want it to go back to the AV RCA cables from the HDMI. -
Change back to HDMI output, then bring the menu up on the TV, then change the output to RCA. Power off the player and change the cables.
You should then be able to select the player via the TV's input selector.ICBM target coordinates:
maybe i was not clear.
the setup menu doe not have an option for video out to be AV RCA cables. -
How did you do it before? Maybe a system reset will fix this. Consult your manual.
AVS to DVD error output video duration is shorter than expected
By gary153 in forum Newbie / General discussionsReplies: 10Last Post: 30th Oct 2010, 17:29 -
What video cards support S-Video & Composite output over VGA via adapters?
By Bix in forum ComputerReplies: 5Last Post: 22nd May 2010, 21:57 -
When i render to dvd in vegas, the output video plays in slow motion, why?
By shadowofanubis6 in forum Newbie / General discussionsReplies: 0Last Post: 1st Mar 2010, 17:41 -
DVD output video is cut off on left and right
By Grunberg in forum Authoring (DVD)Replies: 6Last Post: 10th Nov 2007, 18:18 -
VCR/DVD player with S-Video output
By arturo83 in forum DVD & Blu-ray PlayersReplies: 8Last Post: 16th May 2007, 02:14
