All of my video editing is currently done on WinXP machines with either dual or quad core AMD cpus. For actual editing of video files I use Cyberlink PowerDirector 9(I think). I know how it works, I like it, it does what I want, I don't plan to change that.
For menu creation I currently use DVD MovieFactory but would like to change that. While putzing around with my new laptop which runs Win7 I discovered Win7 DVDMaker. It has awesome full motion menu templates and I would switch over in a heartbeat *but* it limits by time length rather than file size ie even though the AVI files I was using are only 350mb each it will only let me put 3 45 minute clips on a DVD. If I try to put on a fourth it says it's too long. It also has some minor issues with title editing that I might be willing to overlook but I *need* to be able to put 4 45 minute files to a disc. Does anyone know of a workaround or know of software with similar motion menu creation that doesn't have a huge learning curve? I have a project due at the end of the month and I'd like to include full motion menus like the templates in DVDMaker instead of a static image with four video thumbnails and titles like I currently use.
Thanks,
Beth
Main menu/chapters/audio etc all on one motion menu in Encore. Possible?
By Killer3737 in forum Authoring (Blu-ray)Replies: 10Last Post: 11th Feb 2012, 14:08 -
How to edit menu templates in convertXtoDVD
By oodles in forum Authoring (DVD)Replies: 3Last Post: 16th Jun 2008, 12:16 -
Problems when creating a mix with motion menu and static menu
By ihmcjacky in forum Authoring (DVD)Replies: 59Last Post: 15th May 2008, 12:01 -
Software suggestions for video clip or motion menu at the beginning of DVD?
By hitman3000 in forum Authoring (DVD)Replies: 2Last Post: 14th Mar 2008, 20:30 -
Can not find any Menu Templates in EncoreDVD
By acid_burn in forum Authoring (DVD)Replies: 6Last Post: 8th Dec 2007, 17:18
