Results 31 to 40 of 40
Gad am I glad I don't do video editing for a living. Way back there on page 1 I, fool, posted what I then thought was a pretty straightforward question.
Now, 32 posts and 3 1/2 days later, I have yet to get a simple, unequivocal answer...
Oh, well.
That's because there isn't a simple answer.
Video is complex.
Like women. (i.e. Women are From Venus, Men are From Mars)Want my help? Ask here! (not via PM!)
You're right, I lost track among all the ifs, buts, howevers and therefores. I will still make several DVD's differently coded though, as the price of postage to the U.S. one way is probably several times the price of the discs and my time (I get 35¢ an hour).
http://www.kiva.org/about -
Yes, I will send two, maybe three discs coded differently to cover all possibilities. This is no business situation - I'm making the DVD for my brother. Trying PAL first seems like a good idea since, if it works, I won't have to keep track of settings this way and that; I just put together a DVD, standard procedure.
I can do that. I learned it here, on videohelp.com
PAL for quality. NTSC for compatibility. See which works.
Use good discs, to address burn issues.
Hopefully you're using good software, too. Those details appear to be missing.Want my help? Ask here! (not via PM!)
This isn't necessarily true on the screen of an NTSC TV. A PAL disc may have more resolution but the DVD player will convert to NTSC specs for SD analog transmission. It may do a poorer job of downscaling and frame rate conversion than one can do in software. An upscaling player may avoid the downscaling problem but may still do a poor frame rate conversion.
No, I said in the first post that I use AVStoDVD, and that's for DVD authoring. Also, I use DVDFlick for that. For any video editing I use AVIDemux and AVStoDVD.
I'm open to suggestions though. But the software's gotta be menu-driven, easy to use and yield excellent results without my really trying because I'm a lazy, lazy guy...
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 6th Dec 2009, 00:31 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 12:19 -
NTSC-PAL-NTSC (25-23.976+pulldown) and audio sync problem - related?
By ecc in forum Video ConversionReplies: 14Last Post: 14th Nov 2007, 12:34
