  1. Banned
    Jun 2001
    UK
    Got some tips for me?
    Going to install (try to install) the beta phpBB-2.0-RC3
    Things seam to be running good here now, but getting fed of with the winter colours, how about a change
    To change the template is not that easy...you have to manually edit lots of tpl(html) files but if you are good at html it is not that hard. Some php knowledge is also good but not required.
    I used the same buttons but I replaced the blue with red using a batchscript in adobe photoshop so it was very easy.
    The installation is very easy, it is basicly just to type in the database username/password and it makes everything.
    Mar 2002
    South Florida, USA
    Is there any way to can explain how you converted all the images to red in a batch script? I'd be very interested. I'm looking to use this "red sorta theme" on my board.
    - pcmike
    p@pcmike.net
  4. Banned
    Jun 2001
    UK
    What for ?, it can be done within the program, and as already stated Just a few images to load in, edit and save out.
    I have RC4 running now, so far no problems. But it has a lot of admin functions that could be much better.
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    you can only change some colors in the admin panel...not everything...maybe better in the newer versions.
  6. Banned
    Jun 2001
    UK
    You need to watch the mod's, by the time you have them all in place its almost like a final.
    So did you overwrite subsilver then ?
    I'm working on a script that changes them automatically with season changes
