Is there a way I can convert video with ffmpeg to be in mp4 format and play on either iphone or android?
I can't seem to get anything that I convert to play on a phone.
I can get other mp4 files I found to play on the phone but any file I convert into that format won't actually play.
Any help would be very appreciated and I thank you in advance!
Xmediarecode uses ffmpeg to convert videos. It has many presets for specific phones.
You could probably use it to reverse engineer the settings if you want to do it by command line. -
Ok that worked for conversion but won't play in droid phone. I was hoping to have one file that
plays in either droid or iphone. It will play in droid if you load it over and over sometimes it plays
sometimes it doesnt -
What worked? What software and settings?
But, yes it's tricky to get it work fine on ALL android phones. -
Ok I got this further with this:
exec($ffmpegPath . " -i " . $srcFile . " -vcodec libx264 -vpre medium -vpre ipod320 -b 512k -threads 0 -s 480x262 -f mp4 " . $kdest);
exec($ffmpegPath . " -i " . $kdest . " -acodec libfaac -ab 64k -ac 1 -vcodec libx264 -ab 64k -ac 1 -vpre medium -vpre ipod320 -b 512k -bt 512k -threads 0 -s 480x262 " . $destFile);
but the issue I have is if the video is just a few seconds loads super slow like over a minute but then plays fine.
then when you add something that is about 30 seconds in length it takes so long to load it times out.
Play Unsaved Video by Mobile Phone
By kamaldeepdung in forum Video ConversionReplies: 1Last Post: 8th Mar 2012, 05:09 -
What mobile phones uses VFR (or CFR) for recorded video clips?
By Gew in forum Portable VideoReplies: 0Last Post: 27th Jan 2012, 12:49 -
Convert video file for mobile
By xxxThiefxxx in forum Newbie / General discussionsReplies: 3Last Post: 4th Oct 2010, 19:29 -
Convert Any Format to DVD-Video/AVI/Mobile
By lostinlodos in forum Video ConversionReplies: 2Last Post: 21st Oct 2008, 19:36 -
Convert Mobile Video
By phn_uk in forum Video ConversionReplies: 1Last Post: 3rd Jun 2008, 09:27
